New Repeater Questions
EA7KIR
Re: New Repeater Questions
Post by EA7KIR » Wed Mar 11, 2026 12:36 pm
radiogareth wrote:
Wed Mar 11, 2026 12:27 pm
This any good?
Thanks, but it's the printed manual which came with it. Useless for anything out of the ordinary.
Michael EA7KIR
Post by g0mjw » Wed Mar 11, 2026 1:11 pm
Usually these are fairly easy to programme. You need the remote. The idea is to fool it to tune to the required frequency by working out where a satellite transponder would be, at IF. E.g. for 1249 MHz you programme it to 1249+9750 = 10999 MHz. That's assuming a standard LNB LO. Then you set the symbol rate and do a transponder search.
G7VVF
Post by G7VVF » Wed Mar 11, 2026 1:53 pm
I usually create a new satellite called DATV then add a transponder with the required symbol rate, select an LNB that has a LO of 10000, then the frequency will just need a 1 in front of it eg 1249 becomes 11249. Then you have to scan for the transmission and if it receives your signal it will store it as a new channel.
This section of the instructions has the info you need
Duncan G7VVF
2026-03-11 13_51_56-HD 390.zip - File Explorer.png (316.62 KiB) Viewed 82 times
G7VVF
Post by G7VVF » Wed Mar 11, 2026 2:01 pm
Michael,
I don't think your SAT RX will do H265 as it only mentions H264 and "HD 1080" and I think H265 is used for 4K transmissions.
However it does say it will work with symbol rates of 1-45MS/s, so you should be able to run at 1MS/s but not lower and make sure you are transmitting a mode that the RX can decode or otherwise when it scans for your signal it won't find anything.
Duncan G7VVF
EA7KIR
Post by EA7KIR » Wed Mar 11, 2026 2:42 pm
I think I've bought a lemon. If I connect it to my QO-100 LNB, it pulls in 182 channels including Al Jazeera in English that I can watch on my Apple TV. However, nothing from the amateur band and nothing from the LibreSDR sending on 749.25MHz, regardless of FEC or bitrate. The only useful setting available is a list preset LNB Frequency - currently set to 9750 - but no option for FEC, etc.
Michael EA7KIR
Post by G3GJA » Wed Mar 11, 2026 2:48 pm
The Sat Rx will only tune its normal range of LNB IF frequencies - 950 - 2150MHz
The tuner itself might do a larger range but it will be constrained by the software controlling it.
Clive
