Open Tuner 0.1 - Test Version
zr6tg
Re: Open Tuner 0.1 - Test Version
Post by zr6tg » Tue Mar 21, 2023 8:31 am
i4wrm wrote:
Tue Mar 21, 2023 8:11 am
It works great now..!! Good job. Thanks again for your patience and congratulations!! 73 de Ros i4wrm
Brilliant, thanks for the feedback Ros and all the patience from your side with the testing yesterday. Much appreciated.
T
zr6tg
Post by zr6tg » Tue Mar 21, 2023 8:33 am
Request for language translations:
I would like to have multi languages in Open Tuner. If anybody is keen to help translate then please have a look here:
https://docs.google.com/spreadsheets/d/ ... sp=sharing
The google doc contains words/expressions/etc that needs translating. Simply make a copy of the spreadsheet, add in the translations and send/share with me.
If you are keen then probably a good idea to post here so that multiple people aren't working on the same translations at the same time ;)
Thanks,
Tom
Post by radiogareth » Tue Mar 21, 2023 9:44 am
Early days I know but how can I select the other LNB input on my MT?
I have a C band for my local repeater on NIM B and QO-100 on NIM A....(suspect the answer is NOT YET ;-))Thanks
zr6tg
Post by zr6tg » Tue Mar 21, 2023 11:51 am
I implemented it this morning, will be part of next release. ;)
zr6tg
Post by zr6tg » Tue Mar 21, 2023 4:18 pm
New version available: https://www.zr6tg.co.za/open-tuner/
- adds rf input selection
- adds rf input power level (based on https://wiki.batc.org.uk/MiniTiouner_Po ... Indication)
- misc ftdi device detection changes
- added licence to repo
P.S - probably last update until the weekend :) It was long weekend in South Africa so I could spend time on it, but back to work for the next few days. Please do keep the requests/bug reports coming in though.
i4wrm
Post by i4wrm » Tue Mar 21, 2023 6:34 pm
Open Tuner Translation Requirements.xlsx
(10.36 KiB) Downloaded 1669 times
Thanks Tom.. great job!! attached an excel file with the Italian translation. Hello and see you soon !! 73 of i4wrm Ros
Basil
Post by Basil » Wed Mar 22, 2023 1:03 pm
Do these errors, which occur every time, hold any great significance? I played with VNC's settings for hardware accelerated decodings to no avail. Thanks again Tom, fantastic work!
Main: Starting VLC
[068ebce0] imem demux error: Invalid get/release function pointers
Open Media Input
Clearing out TS Queue
Done... starting buffering
VLC: Playing
[068c8b18] direct3d11 vout display error: SetThumbNailClip failed: 0x800706f4
[068c6ea8] direct3d11 vout display error: SetThumbNailClip failed: 0x800706f4
[24622618] main decoder error: buffer deadlock prevented
[2456c928] main decoder error: buffer deadlock prevented
[2456cbd0] mpeg4audio packetizer: AAC channels: 1 samplerate: 48000
Best regards,
zr6tg
Post by zr6tg » Wed Mar 22, 2023 3:57 pm
Main: Starting VLC
Open Media Input
VLC: Playing
Some of the issues are related to my timing on starting vlc to play and then sending the TS data, others are related to it just expecting specific data that isn't sent through most encoded video from our tools. If the video is playing then I wouldn't worry about it, the others I'm working on eliminating. The difference here is that I'm not passing a udp stream to the embedded vlc (like with the longmynd client), but feeding it the binary data directly.
zr6tg
Post by zr6tg » Wed Mar 22, 2023 3:59 pm
Multiple languages support (it,nl, jp,de)
Default offset configurable for both A/B inputs
Error handling on frequency inputs
Simple CPU Load Optimizations
Post by radiogareth » Wed Mar 22, 2023 4:33 pm
Like the green Null packets, very visual.
How can it cope with a C band LNB where the LO is higher than the RX (LO on 5.150GHz, RX on 3.404 GHz, IF 1.75GHz.....
Guess it needs an invert function?
Just tried it rxing me on 437MHz (and 1249) across the shack, that works too :-) But now it needs different Tuner controls for each band ;-)
Lock in 1-2 seconds, great work :-)
