12-13th November Activity weekend
Re: 12-13th November Activity weekend
Post by g8gtz » Mon Nov 14, 2022 5:23 pm
And don't forget we are running an activity ladder for 70cms - it might just be worth you putting an entry in for yesterday Rob!
https://batc.org.uk/contests/70cm-ladder/
pe1itr
Post by pe1itr » Fri Nov 18, 2022 9:20 pm
PA3AUC made troposferic refractivity map of the situation of 2022-11-13 12:00 UTC when I worked Rob M0DTS/p. There is a crosssection of the path between IO94LI and JO30DQ.
73 Rob PE1ITR
KenW6HHC
Post by KenW6HHC » Mon Dec 05, 2022 8:25 pm
An update for the Known-DATV-DX-Records.
I received e-mails from both Rob PE1ITR and Rob M0DTS that they successfully completed a 643 KM 2-way QSO on 70 CM on November 13.
I have added this new DX RBTV (DVB-S2) QSO to the list of Known-DATV-DX-Records that can be seen on the BATC wiki for Section 11 (OPERATING) record inside UK ATV DX Records - a list of Known DX Records for the UK. Go to wiki.batc.org.uk/BATC_Wiki
PE1ITR was located portable in Germany, near Zweifall/Lammersdorf.
Best regards ... de Ken W6HHC
