Activity weekend 2/3rd October 2021
G4NZV
Re: Activity weekend 2/3rd October 2021
Post by G4NZV » Thu Oct 07, 2021 1:16 pm
Give me a hour warning and on what band so I can configure my system.
I have 23cm 35ele yagi horizontal TX&RX but only 2 watt DATV. Also limited to the bandwidth of the transverter and antenna so the useable frequency for TX & RX for me is ~1298.5MHz.
Talkback on Zello is preferred.
73 Steve G4NZV
Graham_J_G3VKV
Post by Graham_J_G3VKV » Thu Oct 07, 2021 7:45 pm
Hi Steve and Rob,
If you could let me know when, would like to see if I can copy you Rob on 23cms -
like Steve I can only TX/RX on 1298.5 Rob but have 45W of DATV to a 20ele.
50W ERP on 146.5 - locator IO81xv 10km from Steve.
73 Graham G3VKV
Post by G4EWJ » Fri Oct 08, 2021 1:12 pm
Rob, I'd like to try 70cm receive in a few days time when I get set up. Bearings are 220 / 40.
I've been talking with G0UHY about trying between Birkenhead and Paignton in a few weeks time. The UN864 airway runs almost directly between us and is much used by aircraft going northwards from Spain to Northern England and Scotland. Aircraft can go magenta (high potential) in AirScout for 15 minutes - sometimes several aircraft at once. It should also be good for the Blackpool area.
Post by M0DTS » Sat Oct 09, 2021 8:34 am
I've got 2x25el yagi up for 70cm, will be ready for tests this evening after 6pm if anyone is available.
I had to take the 2m yagi down to fit them on the mast!
Also available for tests most of Sunday.
I'm listening Zello on most atv channels, ATV South, East, Northeast etc..
23cm Tx tests only on evenings after 7pm due to activity in the yard here, i can receive at any time.
Post by G4EWJ » Sat Oct 09, 2021 2:25 pm
I'll try and get a temporary setup ready for 1800.
Post by g0mjw » Sat Oct 09, 2021 2:37 pm
I can be Rob on 70cm at lease.
Post by g8gtz » Sat Oct 09, 2021 2:57 pm
Yes, I'll be watching 70cms at 6pm tonight - better than Strictly!
Will try to stream what I see on my BATC channel.
G4NZV
Post by G4NZV » Sat Oct 09, 2021 3:11 pm
Hi Rob,
Ready in IO82WA.
To start lets try 437MHz DVBS2 250KS.
Talkback will be essential on Zello ATV North.
73 Steve G4NZV
G4NZV
Post by G4NZV » Sat Oct 09, 2021 3:14 pm
Correction Zello ATV Northeast
70cms tests this evening - Saturday 9th Oct
Post by g8gtz » Sat Oct 09, 2021 4:30 pm
Stream is up and running - I will attempt to relay Zello chat as well.
https://batc.org.uk/live/g8gtz
