Compatiblity DVB-T2 1.7MHz
Re: Compatiblity DVB-T2 1.7MHz
Post by G8GKQ » Sat Sep 04, 2021 2:06 pm
Hi Patrice
Charles developed the original capability. I packaged it for release with the Ryde and the Portsdown, so configuration control comes down to me.
Please could you run the following linux command and cut and paste the response here:
cksum /home/pi/dvbt/CombiTunerExpress
The response should be something like:
<number> 399116 /home/pi/dvbt/CombiTunerExpress
To check what version you have, I need to know the number in the response.
Patrice
Post by Patrice » Sat Sep 04, 2021 2:25 pm
Hi dave,
Please find the answer.
1084327376 399116 /home/pi/dvbt/CombiTunerExpress
Post by G8GKQ » Sat Sep 04, 2021 3:20 pm
Hi Patrice
That is the correct file. I suggest that you look at the RF feed to the tuner (using a spectrum analyser, or Portsdown BandViewer) and make sure that there aren't any big signals within 20 MHz or so. It may be that the Pi Hat can handle those and the Knucker can't.
Other than that, I am out of ideas.
Post by g0mjw » Sat Sep 04, 2021 4:22 pm
Don't the Francophones use a comma for a decimal point? It seems to be working on integer frequency steps. I think this is unlikely but in the early days of my path profile software I came across a similar problem parsing inputs.
Edit - I should add it was an interesting one to find as the inputs looked OK because they were based on the input string. It was only on doing calculations based on a scan of the input string that things went wrong. However as we enter in kHz this won't happen.
Patrice
Post by Patrice » Sun Sep 05, 2021 9:46 am
Charles,
Do you agree with the AVL68XXSDK work flow ?
Patrice
AVL68XX-SDK.docx.pdf
(208.32 KiB) Downloaded 800 times
Post by G4GUO » Sun Sep 05, 2021 11:11 am
Yes, that is what the SDK does.
The main change we have done is to re-calculate the internal clock frequency for narrower channels.
We have not tried to change any of the scan loops. There was a mistake in the manufacturer's code
for 1.7 MHz. Dave fixed that problem. The other thing we added was support for the FTDI USB chip.
Charles,
Patrice
Patrice
Post by Patrice » Tue Sep 07, 2021 2:29 pm
Thank you Charles,
is it possible to have the old version with the original clock to do a test ?
Patrice
Post by G4GUO » Tue Sep 07, 2021 2:40 pm
Thank you Charles,
Patrice
You will have to ask Dave for that.
Post by G8GKQ » Tue Sep 07, 2021 2:43 pm
Patrice
It's here: https://github.com/davecrump/ryde-build ... nerExpress
You'll need to copy it into the correct folder and set it to executable to use it.
Patrice
Post by Patrice » Thu Sep 09, 2021 2:31 pm
The Knucker works (1.7MHz BW) with the old version of CombiTuner.
Patrice
