IARU Region 1 ATV Contest 13/14 June
G8ADM
Re: IARU Region 1 ATV Contest 13/14 June
Post by G8ADM » Fri Jun 12, 2020 12:17 pm
I will be on from home in Pinner. Tx / Rx 70cm 2MS/s and receive on higher frequences...
Post by radiogareth » Fri Jun 12, 2020 2:35 pm
5.7GHz good to go :-) Just hoping Marcel can edit DVBS2-GUI to use the full Pluto RX range before the weekend.
No changeover relays were harmed in making this. It will also work as-is NB directly with the Langstone :-)
Cross-bar bolts to my Surveyors tripod.
2020-06-12 15.23.27.jpg (96.91 KiB) Viewed 10828 times
g4bao
Post by g4bao » Fri Jun 12, 2020 10:42 pm
I plan to be QRV on 146.5MHz (5W to 8ele horizontal) and 23cm (50W ish to a 44 ele) from JO02cg if anyone would like to try.
I will put out a test card at various times on 146.5 and 1255MHz system DVB-S H264 333 FEC 2/3.
Unless anyone can advise me on more appropriate system settings as I'm new to terrestrial ATV
Contact me for a skeds 01223 862480, @g4bao on Twitter, via the ON4KST GHz bands chat and I will leave the SSB RX on 144.750MHz TV chat frequency. Manual changeover of antennas between SSB and TV, so give a few calls, I may be transmitting TV.
Also QRV on 23cm SSB with 200W to the 44ele for sked setup.
Hope to make a QSO!
John
g4bao
Post by g4bao » Fri Jun 12, 2020 10:53 pm
I should probably add that with some wire pulling and cable swapping that I can receive on
10370.5
3402.5
and 24049.0 MHz
using my terrestrial transverters if anyone wants a cross band QSO.
Not quite got round to TXing on those bands yet, but it's just a matter of switchery and drive levels from my Portsdown
Again, call in the places described in the previous post or in fact I have Zello as well
John
g8vpg
Post by g8vpg » Sat Jun 13, 2020 8:18 am
John,
Talkback on 144.750MHz is usually FM; if you can't make a 2m FM contact, you won't be exchanging TV pictures!
73 Shaun.
M0SKM
Post by M0SKM » Sat Jun 13, 2020 9:00 am
I will be on from home in IO91RV. Two way on 1255MHz analogue/digital, two way 437MHz and receive on 146.5MHz.
Contact via Zello or https://dxspot.batc.org.uk/
Steve
Post by g0mjw » Sat Jun 13, 2020 9:13 am
Hope to make a QSO!
John
Hi John - I don't think we have a good enough path to work but I suppose we could test that on FM - my antennas are all horizontal beams though so I need to be pointing the right way for talk back.I have zello too. I am not set up yet, that's this mornings job. Had a lie in after completing those tiring Monday to Friday tasks you can now only dimly remember.
As for system settings I have been experimenting with low rates but for this contest maybe DVB-S2 at 333ks 1/4 rate or 125ks 1/2 rate will be sufficient for sending a contest exchange. Maybe even 66ks without audio would do. Awful pictures unless you use H265 but good enough for a static image with 4 numbers on it
g4bao
Post by g4bao » Sat Jun 13, 2020 10:30 am
[Thanks for that Shaun. wasn't sure. I can of course do FM :-0 !
Do people use H or V pol on 144.750 FM?
73 John
Post by g0mjw » Sat Jun 13, 2020 2:06 pm
M0DHP wrote:
Wed Jun 10, 2020 3:59 pm
I'm planning to operate on Sunday at The Ridgeway IO91IN. 70cm and (possibly) 23cm.
Ray M0DHP
Hi Ray - that Line of sight to me so should work on 70cm
Mike IO91IO
G1LPS Terry
Post by G1LPS Terry » Sat Jun 13, 2020 6:22 pm
We are seeing G7KBZ on 23cm FM ATV anyone know how to contact him????
