Langstone Discussion Forum
Post by g8gtz » Tue Apr 21, 2020 12:08 pm
I bought the "approved" USB audio device but get the no frequency display error - tried another device but still the same.
Any chance of a log file or error display to show what the problem is?
Post by g4eml » Tue Apr 21, 2020 12:18 pm
Hi Noel
This is from memory, so might not be 100% accurate!
SSH into the Pi.
cd Langstone
python SSB_TRX.py
That will try to run the SDR part on its own. You should see any error messages from GNU Radio.
If it works the audio device should start flashing.
Post by g0mjw » Tue Apr 21, 2020 12:25 pm
That's right. I can talk you through it after work Noel and how to fix if you have something else - e.g. another audio device might interfere.
Post by g8gtz » Tue Apr 21, 2020 12:45 pm
OK - get the following:
ERROR: Unable to find host: Name or service not known
Traceback (most recent call last):
File "SSB_TRX.py", line 332, in <module>
main()
File "SSB_TRX.py", line 325, in main
tb = top_block_cls()
File "SSB_TRX.py", line 55, in __init__
self.pluto_source_0 = iio.pluto_source('ip:192.168.2.1', BaseFreq, 529200, 2000000, 0x800, True, True, True, "slow_attack", 64.0, '', True)
File "/usr/lib/python2.7/dist-packages/gnuradio/iio/iio_pluto_source_swig.py", line 126, in make
return _iio_pluto_source_swig.pluto_source_make(*args, **kwargs)
RuntimeError: Unable to create context
Post by G8GKQ » Tue Apr 21, 2020 1:10 pm
That looks like it can't find the Pluto to me, but I'm not good at this Python stuff....
Post by g0mjw » Tue Apr 21, 2020 2:03 pm
Yes - it's not seeing the pluto
Post by g8gtz » Tue Apr 21, 2020 3:03 pm
I did think that but wasn't sure.
Anyway just tried another USB lead and it works :-)
Post by g0mjw » Tue Apr 21, 2020 3:18 pm
The Pluto normally comes with a high quality USB lead with RF chokes on it. Best use that.
Post by g4eml » Tue Apr 21, 2020 6:52 pm
Hi Noel,
Glad you got it working. I have been busy in the garden this afternoon so only just checked the forum.
When I get a chance I will add some more debugging to the start process.
Post by g8gtz » Tue Apr 21, 2020 7:22 pm
Yes - I seem to have a shortage of good micro usb leads (like only 2 in the shack) and I either get the yellow PSU flash or no Pluto!
Got 10's of Mini leads as used on MiniTiouner as I use them for programming the modules!
Anyway - looks like we're getting there :-)
