3D printed case for LimeSDR Mini
G4KCM
Re: 3D printed case for LimeSDR Mini
Post by G4KCM » Wed Feb 27, 2019 12:43 pm
Hi Gareth,
Have dropped you a PayPal. Many thanks for making these.
73 de Clive, G4KCM
G4KCM
Post by G4KCM » Wed Feb 27, 2019 12:54 pm
Blimey! I should have said thanks for the quick delivery it's just arrived.
Much appreciated and it's a super bit of work!
Clive, G4KCM
DL4FBN
Post by DL4FBN » Thu Feb 28, 2019 7:53 am
For those who are interested, I have an offer for the housing of the LimeSDR Mini in milled ALMg3 at a price of Euro 26,00 plus shipping. The aluminium enclosure will improve physically the USB connector joint. I did check the AL printing which showed up at Euro 170 per pcs. There will be no reduction on higher quantities if we follow up the printing way.
If somebody is interested in the aluminium enclosure let me know.
73 de Reinhard
LimeSDR Mini_ALMG3.jpg (222.32 KiB) Viewed 21066 times
ON1RC
Post by ON1RC » Fri Mar 01, 2019 11:19 pm
73 de Reinhard
......and what about cooling?
DL4FBN
Post by DL4FBN » Sun Mar 03, 2019 7:20 am
Chris,
I prefer to do it without a fan. The option is a small heat sink which goes on top. If this will be not enough you can mount the aluminium housing on a aluminium plate and the heat will go away. All hot spots inside have direct contact with the aluminium housing.
73,de DL4FBN
Reinhard
Post by g0mjw » Sun Mar 03, 2019 8:41 am
73 de Reinhard
I am interested - but please before 29th March.
DL4FBN
Post by DL4FBN » Sun Mar 03, 2019 9:09 am
The enclosure has been ordered last week. Usually it takes 2 weeks.
73,de Reinhard
Post by g0mjw » Sun Mar 03, 2019 10:47 am
I will be using 10 MHz reference as it drifts a bit, so may need to drill an extra hole but it looks very good.
DL4FBN
Post by DL4FBN » Sat Mar 30, 2019 4:55 pm
Mike,
there should be no problem drilling a hole and fit a connector. Housings have just arrived after a delay of one week and the lime mini fit ok and the housing take the heat away.
Reinhard
DL4FBN
Post by DL4FBN » Wed Apr 03, 2019 5:26 pm
Chris,
Yesterday I run a short test for an hour and put a small heat-sink on top. There is no need for a fan at all.
73, Reinhard
Return to “LimeSDR Mini”
