ADALM-PLUTO (new DATV SDR)
Post by G3GJA » Thu Aug 24, 2017 12:29 am
My Pluto arrived yesterday; getting good results with bit rates up to 3MS/s but 4MS/s causes the output to 'blip' as seen on the SA and it refuses to lock the Minitioune.
16APSK works with 2Ms/s but not 3MS/s, 8PSK just OK with 2MS/s
I've run the software change to allow a wider range of frequencies but if I try to go below 325MHz the Express transmitter crashes. Not sure whether that's because my Pluto can't be forced to go below 325MHz or if there's a problem with the app.
Thanks for your efforts Charles
Clive G3GJA
Post by g0mjw » Thu Aug 24, 2017 4:56 am
Did you do the below 325MHz hack? It won't work below 325MHz otherwise. There is a link to it further up the thread.
Post by g0mjw » Thu Aug 24, 2017 5:04 am
G4GUO wrote:They are all AD9363s and should work if you follow the software mod details.
We are speculating that AD9363s are AD9364s that did not meet the full performance
when tested and were downgraded.
The mod is reversible
Think you might be right Charles - it may be the software but in SDR# mine doesn't work first time but does later, like its taking too long to achieve lock or it has to warm up maybe. Might be worth putting it in the fridge and in the sun to see if the 9393s work across the temperature range and also looking at the phase noise, sensitivity and output compared to spec. and if there are any holes in the frequency coverage. It doesn't make sense to have two designs like this with identical performance but reduced coverage. It would make sense if the AD9363 had better performance than the AD9694 within its coverage range, but its doesn't appear to have according to the data sheet. Unless of course, export controls are being applied, but then I would expect the limits to be hard coded.
on8ge
Post by on8ge » Thu Aug 24, 2017 5:09 am
Mine arrived yesterday, I am waiting for the corrected software to try it.
Thanks a lot Charles for the big work !!!!!
Pierre
Post by G4GUO » Thu Aug 24, 2017 8:00 am
I will address a few issues.
The crashing below 325 MHz is due to the fact the extended frequency mode has not been done.
Analog Devices libiio which is the interface between my code and the board destroys a channel
if an out of range frequency is selected. That is what causes the crash, there is nothing I can do about that.
I only check the frequency you have requested is between 48 MHz and 6 GHz.
Poor symbol rate performance, unfortunately libiio does not seem to efficiently use the USB2 bandwidth.
It is also machine dependant. On my i7 machine I can get 5 MS/s max performance on my old dual core
machine I can just about achieve 3 MS/s. DATV-Express hardware can achieve 10 MS/s on both machines.
Jerky video, due to the very large buffers required by libiio to maintain USB2 bandwidth the software
currently injects too many NULL packets into the transport stream. It is a bit like trying to talk to
someone on the phone with a long delay, the conversation tends to become very jerky. I am trying to
find an inventive way to get around this problem. Analog Devices has said that later versions of
their library may provide metadata that would enable me better control over NULL insertions.
As you can see these problems are mostly outside my control. I am sure that over time the PLUTO
firmware will improve.
Post by G4GUO » Thu Aug 24, 2017 8:11 am
G3GJA wrote:My Pluto arrived yesterday; getting good results with bit rates up to 3MS/s but 4MS/s causes the output to 'blip' as seen on the SA and it refuses to lock the Minitioune.
Clive G3GJA
Clive I don't think you have done the mod correctly, check that
# fw_printenv attr_name
# fw_printenv attr_val
return the right values someone else couldn't get the extended range to work and it turned out
fw_printenv attr_val was returning "ad9364" when it should have been ad9364 without quotes
M0SKM
Post by M0SKM » Thu Aug 24, 2017 8:54 am
When I hacked mine I made the mistake of leaving the quotes in; it still works down to 48MHz but I can't yet measure above 2400MHz.
Software is much more stable now; although it still transmits momentarily when the software opens.
Good work Charles.
Off I go to take the quotes out....
Post by G4GUO » Thu Aug 24, 2017 9:08 am
Give you some idea of what a pain this thing is to program
below is a very small excerpt from the device info table
the bold item was the one needed to suppress the transmitter.
iio:device1: ad9361-phy
9 channels found:
temp0: (input)
1 channel-specific attributes found:
attr 0: input value: 28947
altvoltage1: TX_LO (output)
7 channel-specific attributes found:
attr 0: fastlock_store value: 0
attr 1: frequency value: 1249000000
attr 2: fastlock_recall ERROR: Invalid argument (-22)
attr 3: fastlock_load value: 0
attr 4: fastlock_save value: 0 126,126,126,126,126,87,126,126,126,126,126,126,244,126,126,157
attr 5: powerdown value: 0
attr 6: external value: 0
voltage2: (output)
6 channel-specific attributes found:
M5TXJ
Post by M5TXJ » Thu Aug 24, 2017 9:13 am
For info;
Currently Digikey are showing no stock on these units, Mouser UK is the same but they are showing an expected delivery shipping 29/8/17. Price is £76.17 + vat vs £76.08 + vat from Digikey.
73 Dave
Post by G4GUO » Thu Aug 24, 2017 9:27 am
Bit of fun, Plutos being tested. The Raspberry Pi seems to get everywhere.
https://www.youtube.com/watch?v=xSO-cFeyDFs
https://wiki.analog.com/university/tool ... rs/testing
