International Activity/Contest Weekend 10/11 June
Re: International Activity/Contest Weekend 10/11 June
The Ridgeway is at IO91IN22TS near Harwell, South of Oxford. I should be set up by 1130 and listening 144.75.
You will be able to see the microwave round table taking place in Chilton at the same time.
Yes Mike - I would like to be there, but the contest takes priority for me.
Thanks Dave.
Steve 2E0XAY was up at his favourite layby near Copt Oak Leicestershire on Sunday.
He was transmitting Analog and recieving GB3VL over 77Km path.
Due to other commitments it is not always possible to fix a day, so bit of a quick dash.
Picture attached of snagged Analog from GB3VL Batc stream.
Also couple of snaps from his location.
Peter
Peter
- XAY-1 Layby.jpg (17.48 KiB) Viewed 10526 times
- XAY-3 Layby.JPG (177.97 KiB) Viewed 10526 times
- XAY-4 Layby.JPG (228.83 KiB) Viewed 10526 times
I did try and rx Steve at Dunstable, saw his signal on the SDR and saw some sync bars on the monitor but no pictures
I was using a 25 ele yagi only 3 ft above the ground as I had packed up due to high winds when Steve called.
Great to see so much activity at the weekend.
Please submit your contest entries to contests@batc.tv. Please also make sure that you get an acknowledgement from me, as some of the entries are falling into my spam folder.
So far, I have entries from: G0WFT, G1LPS, G3KKD, G4GUO, G4KLB, G7AVU, G7JTT, G8GKQ, G8GTZ, G8VAT, M0DTS/P, G3NWR/P and M1EGI.
If you're not on the list (like G3KJX/P, G0EHV, G4CPE, G4CBW, G8LES, G0OUZ, G3UVR, G8DGR, M0IKB and G8VDP) please submit your entry as soon as you can. The form can be downloaded from here http://www.batc.org.uk/contests/ATV_con ... YYMMDD.xls
Edit - new callsigns added 16 and 17 June.
The International Results for this very successful contest have now been published here:
https://vhf-uhf.veron.nl/wp-content/upl ... s-2017.pdf
Congratulations to Rob, M0DTS, on winning the UK section and coming 11th in IARU Region 1.
Congratulations to Rob for top UK entry and to Terry for winning the 9cms section
And thanks to everyone who came on the air and put an entry in making it the most successful IARU contest in recent years - ATV activity is definetely on the up in across Europe and in the UK.
in 2014: 33,
in 2015: 42,
In 2016 52,
In 2017: 95
73's
in 2014: 33,
in 2015: 42,
In 2016 52,
In 2017: 95
73's
