MiniTiouner Hardware version 2
g4pdf
Re: MiniTiouner Hardware version 2
Post by g4pdf » Fri Nov 03, 2017 3:22 pm
This may help somebody constructing... with reference to https://wiki.batc.tv/images/b/b4/Notes_ ... iouner.pdf Figure 4 - Panel layout. The clearance hole diameter for the two 'F' sockets needs to be a minimum of 10.2 mm I suggest. If panel allignment puts strain on the Tuner sockets, the hole diameter could be increased upto 11.00mm or slightly more as required, especially if packing (M10 nylon washers>)and securing nuts (3/8UNF locking half-nuts + plain washers) are fitted either side of the panel.
73 - Bob
Post by g0mjw » Fri Nov 03, 2017 6:07 pm
Oops. I think I copied in the old schematic from V2 - that's not the only error. I might think about fixing it.
G4GHD
Post by G4GHD » Tue Nov 21, 2017 11:08 pm
I know Mike's already posted some of these, but, FWIW, some Farnell codes, should they be of use:
3k3 resistors (5): 9338713
33k resistor 1%: 9340424
56k resistor 1%: 9340742
C2,C8,C10,C12,C14,C15,C16 = 100nF caps: 2395773
C1 = 680uF 25v: 1800652
C3/4/6/7 = 22uF (low ESR): 8812640
C9,C13 = 470uf cap: 1848502
C11 = 1000UF 20% 10V RADIAL: 1902885
D1 = 1N5404: 1863158
D3 = 5.6V *3w version*: 2535671
U7 = 74HC10: 1287482
14-pin IC socket: 1103845
U2/U3 voltage regulators, 3.3V 1A: 1578423
F1 = Fuse holder: 2550632
F2 = PTC 60V 500ma resettable fuse: 2309132
J2/3/4=2 positions headers (3): 1593411
J7= 5 positions header: 1593414
J6/8= 6 positions headers (2): 1022254 (pack of 10)**
**As this is a pack of ten, you can use them instead of the previous headers, just break off what's needed.
USB module headers (2): 1097985
L1/2/3=FERRITE BEAD 998 OHM RADIAL 1LN: 2292298
FT2232H Mini Module: 1697465
Box = (blue): 2361595, (black): 9287876
dh2va
Post by dh2va » Tue Oct 09, 2018 10:08 am
Today I received my parts for the Minitiouner and first of all, a big thank you to all persons involved for such a great kit! From the designers, to the BATC shop to Mike for the building notes!
I hate to be nitpicky on my first post, but is it possible that the panel layout in the building notes (Figure 4) are missing at least one dimension, which is the vertical position of the USB cutout? I think this needs to be 24mm from the lower edge.. was this omitted on purpose?
The NIM module F connectors need a 10.5-11mm diameter, as already stated in another post.
Can't wait to get it all up and running..
73s Achim DH2VA/HB9DUN
Post by g0mjw » Tue Oct 09, 2018 10:13 pm
Glad you have all the parts. I hope your case is the correct colour as it won't work otherwise.
That dimension is a variable depending on the socket you use, so yes its not there on purpose. The image is to scale based on the particular socket I had, the one in the parts list. It was made by photocopying the panel I had drilled by eye and measuring it. The USB module sockets come in various heights, depending where you get them and you don't even have to use a socket. Some people have had trouble with them not making good contacts. For reliability it might be better to solder the module directly to the PCB, but of course that would make it hard to remove.
The F-type threads are for clearance 3/8-32 UNEF so 10 mm would be OK.
dh2va
Post by dh2va » Wed Oct 10, 2018 6:57 am
Thanks Mike for the clarification, I eyeballed the cutout and it fits now nicely. Next step is tinkering with the software..
