PIPO: The best surprise for My Minitiouner
Re: The best surprise for My Minitiouner
Post by G4EWJ » Mon Jul 27, 2015 10:43 pm
Jean-Pierre has done some tests.
http://vivadatv.org/viewtopic.php?f=79&t=402
g0uhy
Post by g0uhy » Tue Jul 28, 2015 2:59 pm
Hi Jean-Pierre,
just downloaded the Pipo version of Tutioune. Tried to run it on the Pipo and I get an error message :- FTD2XX.DLL is missing from your computer.
Any ideas what this file is and can I get hold of it?
Malcolm
G0UHY
Post by g8gtz » Tue Jul 28, 2015 4:26 pm
Hi Malcolm,
Haven't go a Pipo yet (on order) but that sounds like the FTDI USB drivers which can be downloaded from the FTDI site.
F6DZP
Post by F6DZP » Tue Jul 28, 2015 7:22 pm
You have not installed the FTDI driver or not well.
one solution is to search in your disk and to copy the FTD2XX.DLL in the minitioune/pipotioune directory
Jean-Pierre F6DZP
G3UEQ
Post by G3UEQ » Tue Jul 28, 2015 8:14 pm
g0uhy wrote:Hi Jean-Pierre,
Malcolm
G0UHY
Had same problem, put FTD2.dll in same folder as Jean-Pierre suggested, all ok now
Andy G3UEQ
g0uhy
Post by g0uhy » Tue Jul 28, 2015 8:20 pm
Thanks Jean-Pierre,
all ok now. Got a bit ahead of myself...hi.
Malcolm
G0UHY
Post by g8gtz » Mon Aug 03, 2015 8:50 pm
Mine arrived - very nice :-)
I ordered the 64 GB version, however it says drive C is 36.7 GB of which 31.5 is free - which seems odd as its not 32 or 64?
Post by g8gtz » Mon Aug 03, 2015 9:17 pm
Seems very odd not to have a battery in such a small device - I was thinking about adding 14.8v Lipo (very small) in case underneath. For example:
http://www.ebay.co.uk/itm/ZIPPY-Compact ... 1e9bf046da
I guess I could always use one of the switched regs to drop to 12v if the PIPO won't take 14.8v or use the 11.1v version?
Any thoughts?
G3UEQ
Post by G3UEQ » Mon Aug 03, 2015 9:34 pm
Could do, if you have not used lipo's before, make sure you get correct charger as these things can explode quite easily if not correctly charged, also if you drop one on to hard surface quite likely to catch fire and you cannot put them out once ignited. I use these a lot for my drone and model aircraft.
Andy G3UEQ
G4KLB
Post by G4KLB » Mon Aug 03, 2015 11:13 pm
They are 64Gb but have many partitions if you look a bit deeper. I thought I had the 32Gb one at first glance!
