ATV on 6cms - It's Cheap and Easy on 5665MHz
Re: ATV on 6cms - It's Cheap and Easy on 5665MHz
I'm wondering if anyone could shed some light on this nice piece of kit, bought 'surplus' as potentially a 15 watt O/P on stated frequencies. I've had the lid off and there is a string of 5 devices inside with the final PA being one of those 'Frequency stated/matched' devices according to the Toshiba data sheet. I'm hoping it will still have some gain at 5.665 GHz. My only way of measuring its actial O/P will be looking at the increase in spectrum size via a Pluto running SATSAGEN software and sniffing some output near the dummy load or antenna - I bought one of the Grid/Mesh units that BATC were selling at the mini-convention last November.
Drive will be a Pluto via DVBExpress. Rx will be another Pluto running on DVBS2GUI. So far so good.
But what sort of signal/voltage might have been used on the 'gain adjust' input? 0-5 volts, or perhaps a PWM (unlikely??). Don't want to cause harm to what could be a great piece of kit, but not surprisingly, Google did not find any user manual for the product....
TIA - all suggestions welcome (other than 'sell it to me'!!)
Gareth G4XAT
Gareth G4XAT
I run a similar model which produces 9Watts with the circulator removed and just over 8Watts with it fitted. No mods were done to increase power. Very nice piece of kit, I know one other BATC member runs one and gets slightly better results.
Drive is about 0dBm.
73 Steve
73 Steve
Oh, great, thanks
What should I do with the Drive input though? Leave disconnected if it then defaults to maximum gain?
Just got 5.665 working across the shack (DVBSGUI not yet extended for the Pluto up to 6GHz) but SDRAngel does now do DVBS2 and that is working great at 333kS with audio too.
I assumed the circulator might be frequency dependant but its presence (I assume) helps protect the final device?
Is it safe on 13.8V or a definetely 12V only device?
Well done Gareth - that's the amp that most of us use!
Pluto driving it should be fine but you need to loose a bit of power if driving with an FPV unit as it only needs 1 milliwatts. 13volts is fine, although they do get hot as they draw ~8 amps and mine runs ~10 watts. Put a pot between 12v and gnd and take the center to the gain control - start at the gnd end and wind it up for max output - not smoke!
Hope to work you over the weekend - there should be 4 of us on 5.7Ghz DATV.
Note DATV is around 5760 MHz which is center of the NB section and NOT 5665 as most of us are using NB transverters. I'll probably be on 5762.5MHz which is an IF of 146.5 MHz.
Great, Thanks Noel. It should be possible with the gain and power available. Can't persuade my old Win7 Laptop to run SDRAngel properly at the moment but hope Marcel updates DVBSGUI to extend the Pluto tuning as that does run OK on it.
I've some -10dB pads (for using a Pluto with SATSAGEN) that will help with drive curtailment and of course ExpressDVB has a drive power slider.
Good stuff
Good stuff
Hi all,
I have a couple of PAs similar to the one shown and have recently run some tests. I say similar because the type number and frequency range on the label are different. I also have the original power supplies that came with the PAs and on my units the original gain control is achieved using a 100kOhm variable resistance to chassis, with maximum gain = 100kOhms, minimum gain = zero Ohms.
In the linear(ish) region with 10W output the gain is about 53dB, with the gain control giving a 12dB range. The maximum output power was about 16W. DC input 7.9A at 12V. All tests at 5762.5MHz.
As far as I am aware, the PA has not been modified, with the insides looking quite clean.
Irrespective of the label, the PA seems happy at 5762.5MHz. Regarding the o/p circulator, I would leave it there as it's protecting the PA and the improvement in o/p power in removing it may only be a fraction of a dB.
You can see a few photos below.
Jen G4HIZ
Edit: Better photo of test set-up uploaded
Jen G4HIZ
- 5.7GHz PA Test.jpg (1.5 MiB) Viewed 10288 times
- 5.7GHz PA Lid Off.jpg (1.87 MiB) Viewed 10327 times
- 5.7GHz PA OP Section.jpg (1.88 MiB) Viewed 10327 times
- 5.7GHz PA Driver Section.jpg (1.63 MiB) Viewed 10327 times
Very helpful Jen, I'm just adding some PC CPU heatsinks to mine. The gain control pin (when floating) has 7.97V on it. I assume that this is internally sourced in some way and reducing it progressively to ground potential controls the gain. I'll change mine to a 100k and see.
And it works.....across the shack. Gain control (100k to deck) seems quite smooth in adjusting 'received signal strength' although the voltage change per degree rotation isn't very linear.
Needed the second heatsink, it was getting just a bit too hot without it.
Now to arrange tripod fitments etc, or maybe remove my FM-Drone gear from the pair of flat-plates I have already on a mount. That would simplify RX/TX switching.
Doesn't seem to need much drive from the pluto, but no real way of measuring output power at these frequencies ATM. Gareth
Hope it's okay to revive this old thread. Has anyone tried one of the 5.8G 15W drone video tx, as found on AliExpress?
I’ve been considering something along those lines now I’m back in east Essex …..I know there used to be a few people in Kent active on 5ghz ATV ….but not sure if they are still around …or if indeed people still use 5ghz ATV these days .
Interesting on Ali express you can get FPV for all,sort of frequency’s now …70cms 23cms 13cms 9cms 6cms and even some now for 7.2ghz with apparently 3w out on 7.2ghz ….
Anyway saw this one on Ali ….never ordered or dealt from/ with them ..
I just found this on AliExpress: £95.59 | 5.8G 15W Drone Video Transmitter UAV VTX Ultra Long Range High Power FPV VTX 80CH Drone Parts
https://a.aliexpress.com/_EQcaYF4
Steve G3GHZ
Canewdon Essex JO01IO
5665 ATV FM
5665 ATV FM
