Pluto problems - blinking LED1
Re: Pluto problems - blinking LED1
Post by g4eml » Mon Sep 15, 2025 9:50 am
If you are powering the picotuner from USB then you may have problems running both the Pluto and the picotuner at the same time.. Both take a lot of current and the Pi USB ports can shut down due to overload. You may need to power one or both devices from separate power supplies.
Colin G4EML
Rishtonite
Post by Rishtonite » Mon Sep 15, 2025 10:40 am
Thanks for that suggestion. It did occur to me that power starvation to one or both devices could be the problem.
I tried connecting the Pico from a powered USB hub (which is then connected to a USB3 port on the Pi)
From Menu2, File Menu, List USB Devices, entry 4 is PicoTuner
From Main Menu, RX, Recieve, I get 'waiting for Knocker Tuner'
I will check wiki etc. and (hopefully) work out how to power the Pico from 12v instead of USB
Post by g4eml » Mon Sep 15, 2025 10:54 am
Sounds like you are set for DVB-T which uses the knucker tuner. Try setting DVB-S.
Post by radiogareth » Mon Sep 15, 2025 11:26 am
After having it on DVB-T (The Knucker) you may need a re-boot to get it to see a Mini/Picotuner, despite it 'looking' as if its working....
Rishtonite
Post by Rishtonite » Mon Sep 15, 2025 2:49 pm
Thanks for the suggestions.
Pico - now linked JP1 and JP4 and powering it from 12v.
Set to DVB-S/S2. Reboot. Recieve now showing 'searching''
Happy that things now seem to be working as expected.
Now just need to get it linked to my network (which is NOT on 192.168...)
OK. That works. I can access the menus from my PC.
What I still haven't worked out is -
1. when on TX, display (on Pi screen and/or PC) the source. It does for Test Card, but not webcam (or other sources)
2. TX a video file that's on my computer. I presume I need vmix and/or datv easy?
Post by radiogareth » Mon Sep 15, 2025 3:28 pm
The PD 4 should display a RPI camera, contest numbers and any testcard that you have set up. Other sources and you only see the control screen with the TX button in RED.
If you want to TX a video file from your PC, there may be a way via the network to the PD4 but I have never tried that and I think its only for streaming in/out rather than encoding for TX.
Bear in mind that the PD4 is absolutely wonderful for /P or outside/inside demos, but for a more complex 'home station' a PC and (as you suggest) DATV Easy (and others DATVRED etc..) work fine with the same Pluto (and its software) really well with OBS.
DATVEasy and OBS all free and capable of H265 (and H266 which can be received with Opentuner software and achieved amazing quality in tiny bandwidths).
That's all beyond what a RPI4 can do, but in terms of something that 'just works' I reach for my PD4 every time.
Some more info here: https://wiki.batc.org.uk/Portsdown_4#Capabilities
Rishtonite
Post by Rishtonite » Mon Sep 15, 2025 6:19 pm
Thanks Gareth.
On the video source menu (45) I can set comp video or hdmi. I'll experiment with those after reading the capabilities link you've provided.
If they (and webcam) can't be seen on screen during TX, and a newer version of the PD4 software can't incorporate those, maybe another way of monitoring my own transmission would be to build a 2nd Picotuner and 'sniff' (see below) some of the transmitted rf.
I'm only planning on using it from home, connected to my pc.
I've heard about DATVEasy but not investigated that yet.
RF sniffer - I built one for monitoring HF FT8/RTTY/PSK waveforms - https://www.briandorey.com/post/variabl ... al-sampler
Post by radiogareth » Mon Sep 15, 2025 6:31 pm
Yes, the easiest way to monitor it is with.....another PD4 and picotuner. I have a bare-bones screen and RPI4 that I use for in-shack testing where I can plug anything I want into it, although for most shack based RX I use a Ryde on a bigger screen. Its what you have the space and/or funds for really, but out /P its great to know what you are sending not only looks OK (Bandviewer so you don't overdrive your amps etc) or a receiver so you know its good to decode.
Rishtonite
Post by Rishtonite » Mon Sep 15, 2025 10:09 pm
As I've been receiving only, on a PicoTuner, for several weeks now, that does seem to be a good option.
Bandviewer is not something I've used yet, but I presume I'd need a PD4 with a Pi + Pluto (no power amp).
I seems that it's the Pluto doing the receiving, so no Picotuner needed and obviously the antenna connected to Pluto's Rx socket. Maybe a dummy load on the Tx socket just in case I accidentally go into Tx.
Post by radiogareth » Tue Sep 16, 2025 11:43 am
What I usually do is have a PD4 running with a Picotuner for RX that also has some form of SDR also plugged in (RTL, SDRPlay, Pluto etc) fed from a 3-port selection relay itself fed from the RX port of the main antenna relay, usually via a bandpass filter and sometimes pre-amp. Some people have automated this. So when I TX, the isolation provided by two relays lets enough of a signal through to either see you TX or your TX waveform. I've not blown anything up yet......
A second PD4 and Pluto provides the drive and TX signal.
The RF output of a Pluto is not that great and in fact the excellent SATSAGEN software requires you to transmit into the RX port, albeit via a pair of 10dB attenuators.
Bandviewer is already part of the PD4 suite and well worth a play, just a piece of wire in the RX port will show something (local TV around 540MHz, FM broadcast, wifi etc.) Its a really useful facility and works even with a cheap RTL dongle (2MHz view only compared to a Pluto that can show up to 50MHz).
There is a huge amount of support for most areas of the hobby, much of it in the last few years of CQ-TV. If you don't have back issues, they can be downloaded from the shop (members only).
