Pico Minitioune problem
OE8PCK
Re: Pico Minitioune problem
Post by OE8PCK » Sat Apr 27, 2024 7:30 am
I have checked the whole board for hardware mistakes but cannot find any.
Attached is the latest LOG from switch on the stop.
ot_log_2024-27-4--09-22-47.zip
(20.3 KiB) Downloaded 469 times
OE8PCK
Post by OE8PCK » Sat Apr 27, 2024 7:33 am
This is the log when I try and start again without turning the Minitioune off.
ot_log_2024-27-4--09-31-08.zip
(2.93 KiB) Downloaded 394 times
zr6tg
Post by zr6tg » Sat Apr 27, 2024 1:29 pm
Hi Paul,
Can you give give this one a try please:
https://www.dropbox.com/s/9sec0fvvywot6 ... 7.zip?dl=0
73,
Tom
OE8PCK
Post by OE8PCK » Sat Apr 27, 2024 1:57 pm
Hi Tom, this one starts and stops after 30 seconds.
(2.93 KiB) Downloaded 566 times
OE8PCK
Post by OE8PCK » Sat Apr 27, 2024 2:03 pm
This is the log when I start the program new without turning off the Minitioune.
ot_log_2024-27-4--15-58-25.zip
(3.25 KiB) Downloaded 578 times
OE8PCK
Post by OE8PCK » Sun Apr 28, 2024 8:36 am
Hi Tom,
This is my PC specs.
Device name PaulPC
Processor Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz 3.40 GHz
Installed RAM 16.0 GB
Device ID 1E1C1AC8-A0D1-44B3-AFAE-64811AB9397F
Product ID 00342-50660-39837-AAOEM
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Edition Windows 10 Pro
Version 22H2
Installed on ‎02/‎11/‎2020
OS build 19045.4291
Experience Windows Feature Experience Pack 1000.19056.1000.0
Basil
Post by Basil » Sun Apr 28, 2024 10:06 am
Could it possibly be a power supply problem?
When I first built my Minitiouner it would run for a while then crash. The clue was in the power LED dimming or going out altogether. The 12 volt to 5 volt buck converter was faulty. I re-flowed the pads on the thing (Ebay Chinese special...) and it has behaved ever since. Have you monitored any internal or even external voltages?
Just an idea, for what it's worth... Good luck. Chris 2E0ILY
Best regards,
OE8PCK
Post by OE8PCK » Sun Apr 28, 2024 11:05 am
Tnx Basil, I will have a look tomorrow.
OE8PCK
Post by OE8PCK » Tue Apr 30, 2024 10:07 am
Hi Tom,
I have checked and monitored all the voltages from switch on until the program freezes.
All the voltages remain constant and in spec.
As I said the program works really perfectly until it suddenly freezes.
I then turn off the Minitioune and on again, and leave the Pico connected and then the program can be restarted and it remains OK until it freezes again.
Thanks very much for your help.
OE8PCK
Post by OE8PCK » Tue Apr 30, 2024 1:04 pm
This is the Log that runs with the Mini Tioune. I am not sure it is the same as the log.
It shows when the program freezes.
Start Protokoll Mini tioune.zip
(18.13 KiB) Downloaded 370 times
73 de Paul
