7/8 June - BATC Summer Fun Contest
G8ADM
Re: 7/8 June - BATC Summer Fun Contest
Post by G8ADM » Fri Jun 06, 2008 9:31 am
I will be on from home, Harrow, N.W. of London, IO91UO during most of the contest.
Only active on 70cm digital with Tx/Rx
May be analogue and digital receive only on 23/13/3 cm.
Due to a hill to the north I can only see from about 70 degrees thru South to 280 degrees.
I should at least be able to work Peter...
Will listen 144.750 MHz FM and 144.170 MHz SSB (I hope that's the correct frequency!)
73's
G8ADM
g3pyb
Post by g3pyb » Fri Jun 06, 2008 10:09 pm
G3PYB confirming I will be active on 7th June PM from Portsdown Hill IO 90 LU with 100W 70cm DATV 2MS/s FEC 1/2 unless asked for an an alternative. Antenna will be a 46 element J beam.
Sked set for 3pm to repeate contact to North London with G8ADM. C/F 436MHz.
Talkback 144.75 but may need to use 144.725 to escape nearby data box.
I will also take out 10Ghz analoge 4W to 90cm dish., and possibly 5.7Ghz to look for the new Sheffield beacon.
Sunday 8th. from 11am
I plan to be on Walbury IO 91 GI ( Not trig point but carpark near the track) with 70cm DATV again, details as above.
Good take off in most directions .
10Ghz as above,
My have 23cm analog/digital RX with analoge FM TX
Talkback as above
GSM 07776184347
G0DJA
Post by G0DJA » Sat Jun 07, 2008 12:35 pm
House guest has gone home earlier than I thought, so I am now listening 144.750 and watching GB3VL.
I will have to lash up the PA again, as I didn't get time to mount it into the permanent box, but I'll have that sorted a bit later on.
Not heard or seen anyone as yet.
G0DJA
Post by G0DJA » Sat Jun 07, 2008 2:40 pm
14:40UTC and no ATV contacts made yet.
I've been listening since 12:00UTC and called a few times, but no replies yet.
G0DJA
Post by G0DJA » Sat Jun 07, 2008 7:54 pm
19:50 UTC - still nothing heard on 144.750MHz and no replies to CQ calls. Using 100 Watts to a vertical on 2M FM, but that is usually OK for simplex working up to Leeds and down past Nottingham towards the Leicester area. East is flat, out across Lincolnshire and NE towards Hull is usually workable from here.
Is there much activity in any other area?
G0DJA
Post by G0DJA » Sat Jun 07, 2008 8:42 pm
20:36UTC - Still no replies to CQ calls on 144.750MHz and nothing heard on 144.170/175MHz. Although I admit that my 2M antenna is only a vertical.
Nothing seen on GB3VL, other than the test cards etc., although, again, I know repeater contacts won't count for contest points.
Where is everyone? Am I really in such a poor area for ATV that I can't even get through on 2M FM using 100 Watts? Am I the only one trying to put in an entry in this contest in this area?
G0DJA
Post by G0DJA » Sat Jun 07, 2008 9:21 pm
OK - It's 21:18UTC (10:18BST) so I'm giving up for tonight.
Nothing heard on 144.750 or 144.170/175MHz and not even anyone using the GB3VL repeater, so I guess that I'm not in range of any contest stations at the moment.
G0DJA
Post by G0DJA » Sun Jun 08, 2008 9:38 am
M0DTS wrote:The Summer fun ATV contest is coming up in a few weeks and we are hoping to have another go from the North york Moors.
Hopefully be active Sunday the 8th from ~8AM
I think I just heard Rob on 144.750MHz, but at 126km away it was difficult to make anything out using FM.
Saw a picture from Rob via GB3VL a while ago, when I guess he was testing that the gear was working, but not seen any other pictures through VL or direct yet. No other responses to CQ calls on 144.750 or 144.170MHz as yet either.
G0DJA
Post by G0DJA » Sun Jun 08, 2008 11:34 am
Last half hour before the end and still nothing heard on 144.750 or 144.170MHz here.
G0DJA
Post by G0DJA » Sun Jun 08, 2008 12:11 pm
Contest period has just ended and, apart from trying to send and receive pictures with M0DTS/P, I did not hear anyone on 144.750MHz FM nor 144.170MHz SSB. Other than Rob, no one answered CQ calls either.
With the cancellation of the Elvaston Castle Rally, I was hoping that a few people might be about. Did anyone else take part? If so, did you make any ATV contacts at all, I wonder?
Looking at the results of last years contest, I see there were one or two entries on most bands and one person made about 7 contacts on 23cm, and 5 on 70cm and 13cm, from IO93wh, which is 78km from here and I would have expected to hear a signal on 2M FM/SSB from there, so I guess they were not active this year?
I wonder what happened to everyone else?
Dave (G0DJA)
