Open Tuner 0.1 - Test Version
zr6tg
Re: Open Tuner 0.1 - Test Version
Post by zr6tg » Mon Mar 20, 2023 2:19 pm
Hi All, thanks for all the feedback and comments. New version available (2023/03/20), adds lnb supply switching, basic settings to disable spectrum, set snapshot path, etc and also fixes a few small issues.
https://www.zr6tg.co.za/open-tuner/
73,
Tom
Basil
Post by Basil » Mon Mar 20, 2023 3:24 pm
Up and running fine, thanks for the nice updates Tom!
Would there be any support for the snapshot, or a snapshot option to include the data in the LH panel? I sometimes upload screenshots from Minitiouner to include D and MER levels for DATV TX'ers to see their signal here, with data to the chat. I just send a link to the screenshot hosted on my server.
Very appreciative of your contributions to DATV Tom :)
Best regards,
zr6tg
Post by zr6tg » Mon Mar 20, 2023 3:39 pm
Thats an interesting idea, it should be very possible. Will add it to the list :)
T
Post by G3GJA » Mon Mar 20, 2023 5:14 pm
I've run into a problem. It worked OK yesterday with the 20230317 release, but today I loaded 20230320 and now I get the error message below.
Using v2 Minitiouner. tried rebooting, different USB ports etc. Tuner works OK on F6DZP's software. Tried reloading 20230317 version; same result.
Clive
FTD2XX_NET.FTDI+FT_EXCEPTION: An unexpected error has occurred when trying to communicate with the FTDI device.
at FTD2XX_NET.FTDI.ErrorHandler(FT_STATUS ftStatus, FT_ERROR ftErrorCondition)
at FTD2XX_NET.FTDI.SetBitMode(Byte Mask, Byte BitMode)
at opentuner.ftdi.ftdi_set_mpsse_mode(FTDI ftdi) in C:\source\tuner_tests\open_tuner\ftdi.cs:line 167
at opentuner.ftdi.ftdi_init() in C:\source\tuner_tests\open_tuner\ftdi.cs:line 578
at opentuner.Form1.hardware_init() in C:\source\tuner_tests\open_tuner\Form1.cs:line 268
at opentuner.Form1.btnConnectTuner_Click(Object sender, EventArgs e) in C:\source\tuner_tests\open_tuner\Form1.cs:line 360
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.9139.0 built by: NET481REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
opentuner
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/OpenTuner/opentuner.exe
Win32 Version: 4.8.9075.0 built by: NET481REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.8.9032.0 built by: NET481REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
LibVLCSharp
Assembly Version: 3.6.7.0
Win32 Version: 3.6.7.0
CodeBase: file:///C:/OpenTuner/LibVLCSharp.DLL
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
LibVLCSharp.WinForms
CodeBase: file:///C:/OpenTuner/LibVLCSharp.WinForms.DLL
System.Xml.Linq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
websocket-sharp
Assembly Version: 1.0.2.59611
Win32 Version: 1.0.2.59611
CodeBase: file:///C:/OpenTuner/websocket-sharp.DLL
FTD2XX_NET
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/OpenTuner/FTD2XX_NET.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
get:
zr6tg
Post by zr6tg » Mon Mar 20, 2023 6:01 pm
Hi Clive,
Can you check if it does still work with the 20230317 release?
T
G8GYS
Post by G8GYS » Mon Mar 20, 2023 6:30 pm
Worked instantly with my MT-S, an excellent piece of software. Retunes really quickly. Thanks so much! Peter G8GYS
Post by G3GJA » Mon Mar 20, 2023 10:32 pm
Tom
I've found the issue; I had another FTDI connected device plugged into my PC using COM5 virtual port.
Strange that it didn't affect Minitioune, but it's OK on all versions of Open Tuner released so far with the G7OCD USB power meter unplugged.
Clive
zr6tg
Post by zr6tg » Tue Mar 21, 2023 5:33 am
Tom
Clive
Yeah, that makes perfect sense. OT currently just grabs the first two devices and then assumes its the right ones. Minitioune does it smarter by actually detecting the ports. This is also why it works on some Pro 2's and not others, because the 2 ports enumerated in different orders. I have started on making it smarter so it will detect the correct ftdi devices to use. Should be done today. Thanks for the feedback :)
zr6tg
Post by zr6tg » Tue Mar 21, 2023 7:55 am
New updated version - 2023-03-21
- adds better ftdi detection handling, tries to identify the minitiouner type, a couple of visual changes and additions from Chris (dh3cs) to copy the tx freq to clipboard when right clicking on the qo-100 spectrum monitor.
You can grab it at : https://www.zr6tg.co.za/open-tuner/ as always.
btw - please let me know if your device is not being detected properly or there is an issue with the connection after the new changes. It will help if you provide me with the debug around the ftdi detection in the console part which looks something like this:
**** FTDI Ports Detection ****
Number of FTDI Devices: 2
0: is a FT2232H device
Description:USB <-> NIM tuner A
A Fifo: False
B Fifo: True
Should be the i2c port for a BATC V2 Minitiouner
1: is a FT2232H device
Description:USB <-> NIM tuner B
A Fifo: False
B Fifo: True
Should be the ts port for a BATC V2 Minitiouner
Trying detected ports:
i2c port: 0
ts port: 1
Thanks for all the feedback, comments and coffees/beers, much appreciated.
T
i4wrm
Post by i4wrm » Tue Mar 21, 2023 8:11 am
It works great now..!! Good job. Thanks again for your patience and congratulations!! 73 de Ros i4wrm
