Portsdown 4 Update for LimeSDR Mini V2
g8lce
Re: Portsdown 4 Update for LimeSDR Mini V2
Post by g8lce » Thu Mar 16, 2023 2:11 pm
Thanks for all your help. The usual thing mended the problem. Not Ctrl Alt Del, but on/off the router! This has not happened to me before but might help others with a similar 'fault'.
Martin G8LCE
SkyVision
Post by SkyVision » Fri Mar 17, 2023 2:44 am
Hi Dave
Tried Limemini2 first with DATV easy, I got a feeble output around 50db down from normal but it worked.... just
Then tried Portsdown
Updated to latest Portsdown
Updated to lime latest
Applied the DVB firmware, but I bricked it, need to recover it (was this step unecessary?)
Keep up the good work
Cheers Roger VK5YYY
Post by G8GKQ » Fri Mar 17, 2023 9:43 am
Hi Roger
Apologies - I wrote in the LimeSDR Mini V2 article for CQ-TV (soon to be published) that the DVB firmware is not compatible with the LimeSDR Mini V2. I should also have put that in the forum post. I'll see if I can disable the ability to apply that firmware in the software as well.
