The presentation had nothing of note that hasn't already been covered
The accessories appear finalised, with one being physically different to what we've seen so far, pretty $exy actually
I'm under the: if I tell, I have to kill you rules, I can tell you the presenters mic didn't like 6 or 3cms : )
Dave, I asked your questions, so far no response, you would hope the specs are finalised
Been thinking about how the Video works
Assuming the connecting cable is regular POE, encoded video is going to be sent to the ODU FPGA via UDP or RTP, sound familiar
Wireshark would prove that, and the destination IP, the modulator sadly, will be stuck in the analogue mode
It would take allot of lobbying to change that, firmware can be changed but hardware not
The SMAs and the BNCs on the ODUs look vulnerable to the elements, will need rubber boots, amalgam tape or a cover
Where as the POE is weather proof, flying leads look daggy but would be easier to tape up for outdoor use
The SMAs facing upwards on the ODU is not great, a galah (cocky) might chew if off in VK, dropping it would be bad, they need protection
Might be alright for weekend portable use, but the promos show tower installation, think ice or tropical use, IP rating?
Cheers Roger VK5YYY
ic905.pdf
- Amateur Radio - A Love Story
- (47.38 KiB) Downloaded 674 times
