DATV-Easy V2.00
F1EJP
Re: DATV-Easy V2.00
Post by F1EJP » Tue Sep 20, 2022 9:37 pm
For the moment don't update OBS in last version 28 who don't support VirtualCam plugin for all version DATV EASY
I search for alternative solution
73 Dominique F1EJP
Re: DATV-Easy V2.00
Post by g0mjw » Wed Sep 21, 2022 8:03 pm
Hi Dommenique,
See my earlier posts about Droidcam. I have it working with a script. You only need to make minor changes to get it to work.
PE5PVB
Re: DATV-Easy V2.00
Post by PE5PVB » Sun Sep 25, 2022 9:17 pm
Will v2.00 also support interlaced videoformats?
F1EJP
Re: DATV-Easy V2.00
Post by F1EJP » Mon Oct 03, 2022 12:05 am
Hello
@G0MIW
Thank you Mike i implement this solution in next version of DATV EASY 2.07
73 Dominique F1EJP
F1EJP
Re: DATV-Easy V2.00
Post by F1EJP » Wed Oct 05, 2022 10:14 pm
The DroidCam Plugin outputs a frame rate of 29.97 fps even if OBS is set to 25 fps which causes problems to convert again to 25 fps
(2 conversions and jerky image)
For the moment I use the virtual camera integrated in OBS and DroidCam only for the sound !
73 Dominique F1EJP
Hotscam
Re: DATV-Easy V2.00
Post by Hotscam » Fri Oct 07, 2022 10:08 am
Hi Dominique
I am experimenting with DATV EASY 2.06 and it works great. Benno PA3BFX supported me.
Appreciate your work very much.
I love the remote Arduino monitoring for my remote PA but I have a problem.
Communication and analog measurements work fine but I cannot operate the relays.
On the serial monitor the 4 relay control bits are coming in fine but no relays command are generated.
Looking at the sketch Arduino expects to receive "do_high" followed by a substring command.
I cannot see this string coming in on the serial monitor from the PC and Easy.
Is that a version problem ?
73's
Jack PA3AXO
Jabi
Re: DATV-Easy V2.00
Post by Jabi » Wed Oct 12, 2022 12:14 pm
Hi Dominique:
If it is possible, please send me one copie of Datv 2.06 for testing and writing about it in spanish revue of Ure ( spanish radioamateurs association).
73,s de Jabi, ea2aru.
F1EJP
Re: DATV-Easy V2.00
Post by F1EJP » Wed Oct 12, 2022 10:28 pm
I send for all beta tester the new version 2.07 with documentation in Dropbox
if no major problem is reported I will quickly publish this version. :D
@ Jack there is a new program for Arduino not the same than for 1.25. the program is provided in the program zip
The order has changed "do_stat" and data on 4 digit.
Thanks at all for your test return
73 Dominique F1EJP
Jabi
Re: DATV-Easy V2.00
Post by Jabi » Thu Oct 13, 2022 4:54 am
Hi again Dominique:
Many tnx for the info.But, if is possible, please, send me the beta versions for running and test it? My email is: jabieraru@gmail.com. O send me the Dropbox direction.
PE5PVB
Re: DATV-Easy V2.00
Post by PE5PVB » Thu Oct 13, 2022 8:35 am
Did you update the audio samplerate to 48kHz?
