Activity Weekend 9/10 April 2022
Re: Activity Weekend 9/10 April 2022
Another interesting afternoon with my new 70cms amp being given a good work-out/test...which it survived....
Out tomorrow morning at Burton Dasset Hills (approx IO92GD99) around 9:30 (realistically 10am) depending how fast I set up with 70, 23,(13, 9) and my experimental (but works) 6cm lash-up. Also hope to test out 10GHz/P receive with a couple of different dishes.
Another fun session on 70cms - the band that never disappoints!
I stayed at home but still managed to rxr G4XAT and G4CPE via Aircraft scatter.
No joy with Rob up on the moors but managed a 2 way on DVB-S2 and DVB-T with Dave G8GKQ/p out at Lane End near Winchester.
As mentioned in CQ-TV, BATC is running an activity ladder on 70cms for 2022 - don't forget to put an entry in for any contacts on 70cms: https://batc.org.uk/contests/70cm-ladder/
Took a quick snap from GB3SQs local monitor of Dave's signal into the repeater.
Could you say what frequency and modulation are in use?
Set up gear at home.
Put 144.750 on. Heard nothing on either day.
Looks like you need to be portable or have a high QTH.
Oh well it may be better next time.
Put TV equipment back in loft.
It's right there in the image. 437 MHz, 333ks, DVB-S2 QPSK FEC 2/3
A really enjoyable Saturday afternoon out gaining more experience with DVB-T and also accessing GB3SQ (with DVB-S2) on 437 MHz at 57 km.
Some interesting multipath effects seen on BandViewer when Noel was transmitting DVB-S2 and beaming away from me.
- snap66.jpg (73.18 KiB) Viewed 16250 times
I only managed to repair my 70cm PA yesterday so missed the chance of going to Clee Hill, Shropshire.
Today's best DX was 500 mm!
Here's new build Portsdown 2020 transmitting on 437 MHz 333KS DVB-S and being received by my Portsdown 4. Filter modulator and associated boards are ex-G8GTZ bought at CAT21 and doing the transmitting.
The new unit is for Wolverhampton ARS G8TA in its centenary year. The club is a BATC member. It's part of my cunning plan to have another working station somewhat nearer than 100 miles away! Apart from G8VZT I don't know of on air DATV kit in the West Midlands.
I think Rob's mast looks so heavy that he's taking up body building. I hope you have a good time out and about.
David M0YDH
David M0YDH
- G8TA/P is received across the bench
- PhotoPictureResizer_20220410_134457_copy_1008x567.jpg (192.92 KiB) Viewed 16249 times
Gareth's 70cm signal from IO92GD 60 km away. In IO82UC the antenna was a Loft mounted Dual band antenna (5 ele on 2m 9 + ele on 70cm) fixed east+HA8ET preamp. I ran 3w and had a 333kS MER of 4dB
G4FRE
G4FRE
Thanks to Dave (above) I/we enjoyed a protracted but largely very successful day out. My summary below while I can still remember it all!
What a day.....70cms, 13cms QRP, 3.4GHz experiments 5.7GHz DATV and FM TV , plus a visit from the MOD Police!
As planned I set up at Burton Dassett Hills just south of Gaydon on the M40, the site of my successful amplifier tests on 3.4GHz a couple of weeks ago. Although I had successfully run-up my new big PA for 70cms yesterday, as it needed up to 750Watts of DC input I left it and the necessary generator at home and opted for lighter loads. Despite this the days activity consumed 42A/Hr from my leisure battery and another 6A/Hr from one of my Li-ion laptop packs (10.8V 98W/Hr) the latter being good enough to run my Portsdown4 for around 5+hours and which allows for moving it around between tripods/parcel shelf etc.
So to 70cms, easy contacts both ways with Dave G4FRE but despite protracted trying nothing was seen from Arthur or Steve further south. This was a bit surprising given their power and the relative distance, but it was no-go. Upward to 3.4GHz where the previously tested new Toshiba amp was fired up to confirm signals. Interesting that they were not quite as high as previous, but having set the bar, I moved on to testing my Stealth (Purple heat-sink) amp and establishing suitable drive levels for that. Tests complete on the amps, I moved on to try firstly a BSB mini-dish fed with a bi-quad, this was reported as about -10dB on my 16-patch flat-plate. A similar test with a double bi-quad yielded similar signals but a lot less windage. Useful for the future, I can leave something at home.
As it was also a u-wave contest day Dave and I used our Langstones to exchange 5/9/001 on very strong SSB signals. Upwards to 5.6GHz and my 'somewhat hopeful but worked really well' solution to receiving worked too, again Dave provided feedback on the strength and shape of my DATV signal. Two-way DATV and one-way (my TX to Dave) worked on NB too. As the gear was on the tripods we both connected up our 5.665 drone FM tx/rx and we exchanged nice quiet 'P5' FM pictures. At this point I lowered my 70cms beam and swapped it for the 13cm 46ele loop-yagi. This thing goes like a rocket and copy was nearly achieved with what turned out to be a few mW leaking through my U/S 13cm mini-pa. Well it worked last time I used it..... So we tried JUST using the pre-driver, one of the eBay 50MHz-6GHz do-it-all amps. And it worked – 50km with a MER of 14 from 50mW. That's another one to add to my G-QRP club tallies
But what about the MOD Police visit? Someone early on in the day reported me as looking like I was undertaking 'suspicious activity' so he was duty bound to investigate. Evidence of who I was (drivers license and car reg) was duly logged, investigated and given the all-clear. (https://en.wikipedia.org/wiki/MoD_Kineton) Several interested people asked what I was up to and nobody suggested that I used my mobile phone instead
Despite the sunshine, which was very pleasant, there was a chilly breeze most of the day, necessitating TWO woolly hats, a sweatshirt, armless fleece and an anorak over the top of it all. I still wished I'd packed a scarf.
Kit tested, hardened, faults found, kitlists needed and those blasted RP SMA used on the FM 5.6GHz gear need changing, although a rummage through the multiple connectors boxes produced one workable solution.
After the 70cm success on to the higher bands
First 9cm, where similar results to the previous monday nigh9cm signals
(I ran 7W to a 15dBi horn)
next 6cm DATV (I ran 4W to a panel antenna) After working on 6cm DATV we moved on to 6cm FMTV (I ran 8W to a panel Antenna)
Next we moved onto 13cm where initial signals from Gareth were a MER of 1.5dB, So he switched to his Chinese preamp and signals suddenly got loud!
(I ran 5W to a panel antenna)
I had 2 way SSB qsos on 13cm and 9cm with Gareth (one way on 6cm as his RX didnt work)
I also worked Walbury hill IO91GI on SSB on 9cm and 13cm which opens up some DATV possibilities! (never works from the Combe IO91GI site)
G4FRE
G4FRE
