Building a Ryde help please
G1BVI
Re: Building a Ryde help please
Post by G1BVI » Sun Mar 28, 2021 3:46 pm
I was wrong this m/c is not behind the DNS :-(
Connected direct to master router and I get lots of this..
ng?
Reading package lists... Done
Building dependency tree
Reading state information... Done
libasound2-dev is already the newest version (1.1.8-1+rpt1).
The following packages were automatically installed and are no longer required:
distro-info-data iso-codes lsb-release python-apt-common python3-apt
Err:1 http://archive-bm.raspbian.org/raspbian buster/main armhf python3-lib2to3 all 3.7.3-1
Cannot initiate the connection to archive-bm.raspbian.org:80 (2001:41c9:1:3ce::1:10). - connect (101: Network is unreachable) Could not connect to archive-bm.raspbian.org:80 (5.153.225.231), connection timed out
Err:2 http://archive-bm.raspbian.org/raspbian buster/main armhf python3-distutils all 3.7.3-1
Err:3 http://archive-bm.raspbian.org/raspbian buster/main armhf dh-python all 3.20190308
Err:4 http://archive-bm.raspbian.org/raspbian buster/main armhf libexpat1-dev armhf 2.2.6-2+deb10u1
Err:5 http://archive-bm.raspbian.org/raspbian buster/main armhf libpython3.7-dev armhf 3.7.3-2+deb10u2
Err:6 http://archive-bm.raspbian.org/raspbian buster/main armhf libpython3-dev armhf 3.7.3-1
Err:7 http://archive-bm.raspbian.org/raspbian buster/main armhf python3.7-dev armhf 3.7.3-2+deb10u2
E: Failed to fetch http://archive-bm.raspbian.org/raspbian ... -1_all.deb Cannot initiate the connection to archive-bm.raspbian.org:80 (2001:41c9:1:3ce::1:10). - connect (101: Network is unreachable) Could not connect to archive-bm.raspbian.org:80 (5.153.225.231), connection timed out
E: Failed to fetch http://archive-bm.raspbian.org/raspbian ... 08_all.deb Cannot initiate the connection to archive-bm.raspbian.org:80 (2001:41c9:1:3ce::1:10). - connect (101: Network is unreachable)
E: Failed to fetch http://archive-bm.raspbian.org/raspbian ... _armhf.deb Cannot initiate the connection to archive-bm.raspbian.org:80 (2001:41c9:1:3ce::1:10). - connect (101: Network is unreachable)
I will check router settings and see if something has been set by mistake.
I thought apart from the Pi-Hole that is my DNS it was clear.
At least I know where to look now
Nick
G1BVI
Post by G1BVI » Sun Mar 28, 2021 6:26 pm
I give up Dave
Router is set to unrestricted and it is failing to download as above.
Ordered a card from the shop
I will get to the bottom of this though when I have more time.
Thanks for your help
Nick
g8lce
Post by g8lce » Mon Mar 29, 2021 11:21 am
To test your Internet and RPi you could try loading the standard operating system with desktop and see if that works. If it does then start again with Ryde software from formatted SD card.
Martin G8LCE
MW0RUD
Post by MW0RUD » Mon Mar 29, 2021 11:40 am
It looks like there were issues with the default Raspberry Pi mirror over the weekend: https://www.raspberrypi.org/forums/view ... 6&t=308028
Tim
Nick
Post by Nick » Mon Mar 29, 2021 11:44 am
I had problems with software for Ryde. In my case it was caused by using the Three 3G network via a dongle in the router for the internet connection. It always corrupted the download for some reason, but was OK with the Portsdown downloads.
I solved this by switching back to TalkTalk for downloads which although much slower worked OK.
I now do not update the SD cards using the built in features. I now just create a new card and swap it with the existing one. If it does not work I can just swap the SD cards back. Takes longer, but at least you have a working card available if required.
Nick - G4NKV
G1BVI
Post by G1BVI » Mon Mar 29, 2021 12:24 pm
Thanks All
I will have another go tonight but did order a card from BATC.
Buster came down OK
Not sure how you format a SD in windows after it has the linux RPi image etc set up.
Google is your friend
Watch this space
73 and Tks
Nick
G1BVI
Post by G1BVI » Mon Mar 29, 2021 12:26 pm
Just read the Rpi Forum Thanks Tim and that is EXACTLY what happened to me.
Spent hours trying and retrying
Arrgghhhhhhhhh
Tonight I will try again
Nick
Nick
Post by Nick » Mon Mar 29, 2021 2:03 pm
To reformat a SD Card with Windows use SD Card Formatter.
Download from https://www.sdcard.org/downloads/formatter/
Nick - G4NKV
G1BVI
Post by G1BVI » Tue Mar 30, 2021 8:43 am
What a Difference a day makes..........................
Did not reformat the card just ran install again and ...................... no unreachable errors.. it works..........
I spent............... hours pulling my hair out on Sunday trying to download the Ryde s/w
I went through my router settings etc.. etc...
How many times I lost count.
Every time the same.
How Dave managed to download it threw me, so I can only conclude that either Raspbion have different repositories in different areas of the country or there was some other breakdown.
I know that she who must normally be obeyed was getting scared of me Hi Hi.
I was not in a good mood :-)
Ordered a new SD card and a BATC flashed card Sunday so if anyone wants a BATC flashed card let me know:-)
Too much wine last night to do any more tests but it all looked good.
Thanks all for help
Nick
