Ryde Update With Support for QO-100 Quick Tune
Don_EI8DJ
Re: Ryde Update With Support for QO-100 Quick Tune
Post by Don_EI8DJ » Mon Feb 01, 2021 12:48 pm
Many thanks to Rob and company for the efforts here, it makes operating both minitiouner and ryde a pleasure.
well done all.
Don EI8DJ / M0JJY
dl6rcg
Post by dl6rcg » Tue Feb 16, 2021 7:01 pm
Hi all,
I want to control my RYDE (latest software version) with QuickTune V1.22b but I do not have "QO-100" in the "Select band" list when I want to add a Ryde receiver. Do anybody have the same problem and a solution? Looking forward for answers.
73 de Tom, DL6RCG
Post by g4eml » Tue Feb 16, 2021 7:13 pm
Quicktune reads the bands from the Ryde so if you are not seeing them it would suggest the connection to the Ryde is not working.
dl6rcg
Post by dl6rcg » Tue Feb 16, 2021 7:22 pm
The connection is working. I can see 10368, 146,437, 1255, 2400, 3400 and 5760. But not QO-100.
Post by g4eml » Tue Feb 16, 2021 7:33 pm
Can you see the QO-100 band using the Ryde onscreen menus?
If it is not there then you may need to re-create it by logging into the Ryde and using the menu.
dl6rcg
Post by dl6rcg » Tue Feb 16, 2021 8:12 pm
No, I can not see QO-100 in the Ryde onscreen menu. Only the frequencies which I can see in the QuickTune band list.
How can I re-create QO-100?
Post by G8GKQ » Tue Feb 16, 2021 8:45 pm
You should log in to the ssh terminal, enter menu and press enter.
In the menu, go done to settings, and then "Restore Factory".
Then go back to Receive and check for QO-100 again.
dl6rcg
Post by dl6rcg » Tue Feb 16, 2021 8:52 pm
Thank you Dave, it is working! :D :D
Also thanks to g4eml
73 de Tom, DL6RCG
dc1op
Post by dc1op » Wed Feb 17, 2021 10:42 am
Found an hour yesterday night to update my Ryde and install the Quick Tune module. -> it is really a great pleasure to work with it, no hick-ups while updating and installing.
Special thanks to all the „cooks“ being involved in the development of this feature.
dc1op, Hubertus
dl6rcg
Post by dl6rcg » Wed Feb 17, 2021 6:18 pm
Hi all,
today I found out the reason why the "QO-100" was not visible in the "Select band" list. If I change the RF input from "Top" to "Bottom" connector of the tuner in the menu then after rebooting "QO-100" is gone. If I leave it as it is then Ryde is working perfect. Is this behaviour a known software bug?
Best regards de Tom, DL6RCG
