"3D Sound" USB audio adapter
Re: "3D Sound" USB audio adapter
Post by G8GKQ » Sun Oct 18, 2020 4:26 pm
Hi Graham
If you are using a non-standard audio output, you will need to edit line 56 of rpidatv/scripts/lmvlcff.sh:
  AUDIO_DEVICE="hw:CARD=Device,DEV=0"
to be correct for your audio device.
Try running
arecord -l
at the command line. That will give you a list of audio devices.
Changing that file will only make the change for main receiver player. Any other audio outputs (like the stream receiver) will also need to be edited separately.
g3yjr
Post by g3yjr » Mon Oct 19, 2020 8:38 pm
Thanks Dave. I'll give that a try.
Graham
g3yjr
Post by g3yjr » Thu Mar 11, 2021 3:06 pm
Dave, I returned to the Portsdown project this week.
I am using the "3D Sound" USB dongle. For Langstone, I have amended the Lang_RX.py and Lang_TX.py files by running set_sound and selecting hw:CARD=Set,DEV=0. Langstone gives sound via the dongle OK.
I upgraded Portsdown to version 2021022250. I executed arecord -l as you suggested. This gave:
card1: Set [C-Media USB Headphone Set],device 0:USB Audio [USB Audio]
subdevices: 1/1
Subdevice #0: subdevice #0
In lmvlcff.sh as you suggested (ine 57 on my editor) I found:
if [ s? == 0]; then
AUDIO_DEVICE="hw:CARD=headphones,DEV=0"
I amended the then clause of the nested if statement,
replacing CARD=headphones with CARD=Set.
On re-booting Langstone, I got sound through the USB dongle from LongMynd. So now both Langstone and Portsdown output sound via the "3D Sound" dongle. Then I realised that I'd left Audio Out = RPiJack in Config; this is literally wrong, but the USB sound works, so it is right as far as I am concerned!
Thank you for your help.
I wonder what the ALSA device in the else clause refers to?
73 Graham
