HDMI to USB on Portsdown 2020
Re: HDMI to USB on Portsdown 2020
Post by G8GKQ » Tue Oct 20, 2020 10:10 am
Whilst I am very pleased that users are experimenting with new capabilities, I would like to emphasise that this HDMI input device is not properly supported in the Portsdown software.
One of the problems is that there are 3 different encoding methods used for different modes in Portsdown and each handles different video capture devices differently:
  • MPEG-2 on all devices except the Pluto uses an ffmpeg encoder
  • The Pluto is not capable of transmitting MPEG-2 from the Portsdown
  • H264 on all devices except the Pluto uses F5OEO's avc2ts encoder.
  • H264 on the Pluto uses ffmpeg to encode an rtmp stream, which is then transformed into a transport stream in the Pluto
The Portsdown is not like Windows or Desktop Linux - it is an "appliance" designed for specific tasks.
My preferred HDMI capture device is the LKV373A, and the Portsdown 4 does support use of this device to stream to the BATC streamer.
Jabi
Post by Jabi » Thu Oct 22, 2020 7:13 am
Ok. And many thnks to all.
73,s de Jabi, ea2aru.
Jabi
Post by Jabi » Thu Oct 22, 2020 11:04 am
Hello. Is possible, please, aucun om send me instructions or/and example for work (and play) with OBS and Porstdown 4? I have ready all, but not is clair for me...
G1LPS Terry
Post by G1LPS Terry » Thu Oct 22, 2020 6:46 pm
Please remember that HDMI to USB dongles aren't supported. just experimenting
Tried another type today and this one works much better DVB-S to sym rate 4000 and DVB-S2 all the way up to 32APSK.
limited testing to-date, but found if I enter the transmitted parameters manually into MiniTiouner it received everything I tried sofar
G1LPS Terry
Post by G1LPS Terry » Thu Oct 22, 2020 6:51 pm
32psk
KA5BBC
Post by KA5BBC » Thu Oct 22, 2020 10:56 pm
Terry.. can you share links to the items you are buying please.
Andy, KA4BBC/MM0BQV
Post by g0mjw » Fri Oct 23, 2020 7:49 am
There was an article in CQTV 265 by G7JTT on OBS and Portsdown. If you are a member you should be able to download it. If not perhaps it can be shared / put on the Wiki. There is already quite a lot of information on the Wiki https://wiki.batc.org.uk/The_Portsdown_Transmitter and the method for VMIX is explained https://wiki.batc.org.uk/Feeding_Video_ ... _from_vMix which is quite similar to OBS.
keng8vdp
Post by keng8vdp » Sun Oct 25, 2020 12:39 pm
https://www.amazon.com/Gimama-Definitio ... B08CVRL987
Looks the same BUT spec only claims 30fps
Also this, look carefully at the specs. >>>eBay item number: 264858225618
