High power attenuator
Re: High power attenuator
Post by radiogareth » Tue Jul 07, 2020 2:47 pm
Using this calculator https://www.pasternack.com/t-calculator-pi-attn.aspx and my stock of resistors, I settled on a 820 ohm unit to give me something close to 30dB and 50R. Re-testing it shows reasonable flatness +/- a dB up to 500 MHz, then it goes all over the place, dropping to -22dB at 1.5GHz but falling (rising??) to -50dB at 5.8GHz....subject to test equipment vagaries and operator error. At worst I have a 'pair' 100 watt dummy loads accessible from each end....
Post by radiogareth » Fri Jul 10, 2020 7:16 am
Developing the theme I saw this idea on a Russian MRF300 amp video (144MHz in this case). I did something similar a while back with a 50R thick film resistor on a PC heatsink, with a BNC mounted directly above the socket and it works well.
My question is, is the termination method shown better that a short wire to a BNC in and out socket mounted a few cms away?
I'd guess that as short a lead-in as possible is the best and by using some HD solder tags under the attenuator fixing screws, I can get down to negligible lead lengths using coax flying leads with the braid solder-flooded and secured by the solder tags.
Shorter is better.....?
