Langstone Across LAN
G1LPS Terry
Re: Langstone Across LAN
Post by G1LPS Terry » Fri May 01, 2020 7:26 pm
I am having several issues with a Rev. A pluto.
I saw Colin updated the Github today with waterfall so tried installing and it doesn't show on my Rev A. but everything else works. tx rx freq change etc.
Also the the con-fig file wont accept Lan settings? (edit save eject)
I now have Lan working with a network adapter with the small otg on it. On a Rev B Pluto.
The waterfall also is working on this revision.
Ill have to update the firmware on the Rev A and try again.
The otg to Ethernet adapter that worked is Branded "Plug able" fast Ethernet (small black plastic case no USB hub) Borrowed from GB3KM new build ;)
Thanks help Terry
Post by g4eml » Fri May 01, 2020 7:40 pm
Interesting, the waterfall is created by the GNU Radio module and not directly from the Pluto. That would tend to suggest that the Rev A Pluto is not actually providing any samples. If it will take the later firmware then I would think that would get it working.
G1LPS Terry
Post by G1LPS Terry » Sun May 03, 2020 7:44 pm
following on from my above post.
the Revison A pluto I was having issues with started working today after I updated the latest changes to Langstone. :)
DL5BCA
Post by DL5BCA » Sat Jul 04, 2020 10:48 am
Hi at all,
wouldn't it be helpful to make the IP address adjustable via the menu?
73 Tommi
I always have crazy ideas.
Please don't be surprised.
Post by g4eml » Sat Jul 04, 2020 1:00 pm
Good idea, but not easy to do! Maybe one day.
DL5BCA
Post by DL5BCA » Sat Jul 04, 2020 1:34 pm
Hello Collin,
thank you for your answer.
Can you tell me the files in which i need to change the ip address?
Maybe an idea to explain the change of the IP address using instructions?
I could imagine that other OMs would also like to operate the Pluto near the antenna.
73 Tommi
Post by g4eml » Sat Jul 04, 2020 4:05 pm
You should not need to change the address, I am using ip:pluto.local which should work with any address.
If you want to hard code an address then you need to edit 3 files
Lang_RX.py
Lang_TX.py
LangstoneGUI.c
Changing 'ip:pluto.local' to 'ip:192.168.nnn.nnn'
Note that using the Pluto over a local network needs a fast connection and minimal other traffic. A dedicated separate network connection may be needed. Some people have also needed to increase the buffer sizes in the python files.
DL5BCA
Post by DL5BCA » Sat Jul 04, 2020 5:06 pm
Hello Collin,
Thank you again.
In the Next days i will Test it...
73 Tommi DL5BCA
