Scan&Tioune
F6DZP
Re: Scan&Tioune
Post by F6DZP » Sat Apr 18, 2020 3:04 pm
@G4UVZ
Do you see what is written in the middle of your last screenshot?
Jean-Pierre F6DZP
G4uvz
Re: Scan&Tioune
Post by G4uvz » Sat Apr 18, 2020 4:48 pm
Now resolved when I managed to stop my 64bit machine downloading VLC 64////32VLC works OK
Re: Scan&Tioune
Post by g0mjw » Sat Apr 18, 2020 5:14 pm
I don't seem to be able to have both 64 and 32 bit VLC on my machine at the same time, at least not with the standard installer. Does anyone know how to fix this?
F6DZP
Re: Scan&Tioune
Post by F6DZP » Sun Apr 19, 2020 4:49 am
I have both versions 32bits and 64bits installed at same time on my PC and both can work at same time.
I have done nothing special, just installed both versions.
Jean-Pierre F6DZP
G7JTT
Re: Scan&Tioune
Post by G7JTT » Sun Apr 19, 2020 9:06 am
GM Jean-Pierre
I see in the ini file you can set the local ip for receiving station configurations, is this implemented in this version ?
I have set the Ip address to my local Ip but I'm not able to change the settings in Scan & Tioune remotely.
73 John G7JTT
F6DZP
Re: Scan&Tioune
Post by F6DZP » Sun Apr 19, 2020 12:56 pm
Hello John,
Yes, you can set the local IP you want to use in the .ini file
You can check if it is used by clicking the "info" button (at the top).
Jean-Pierre F6DZP
G7JTT
Re: Scan&Tioune
Post by G7JTT » Mon Apr 20, 2020 7:13 am
Thank you JP 👍
