Portsdown Software Update 201912100
mm0mgb
Re: New build with Lime - H264 not working.
Post by mm0mgb » Mon Jan 06, 2020 3:17 pm
not really but I have 2 full pi and lime set ups and both behave the same way currently. I'll carry on fiddling to see if theres anything odd with rf getting into the pi etc,
Andrew
Re: Portsdown Software Update 201912100
Post by G8GKQ » Mon Jan 06, 2020 4:07 pm
Hi Andrew
I have moved the posts to somewhere more relevant as you are using this latest update.
Have you updated the LimeSDR USB Firmware at all? I would not recommend it, but that could be one cause. The last testing I did with a LimeSDR USB was with Firmware Version 4, Gateware version 2.20.
Please could go to the Command Line and try
LimeUtil --make
and then
LimeQuickTest
and post the results here?
