radiogareth wrote: ↑Wed Dec 11, 2024 4:42 pm
I did own one of those but found it a lot easier to use my Portsdown/bandviewer to find the NB beacons and then the WB, aided by a compass and a Lidl Inclinometer.
That it only did 1000ks and above, plus a not-obvious-to me method for entering the required data meant I sold it on.
I started with this and found it pretty quickly
https://eshail.batc.org.uk/point/
Not just the symbol rate, which is probably OK, but it also needs to tune down to the low IF you get from a standard LNB on QO100. The manual doesn't say unfortunately but the forums say the tuner covers 950-2150MHz. If that's true, it cant tune down far enough.
