October Low band activity weekend (20th - 21st)
g8vpg
Re: October Low band activity weekend (20th - 21st)
Post by g8vpg » Wed Oct 17, 2018 3:06 pm
Ken G4BVK will be at Westbury White Horse, Wiltshire, IO81WG, on Sunday from about 1030am onwards. He will have 71 & 146.5MHz, talkback 144.750MHz horizontal & Zello.
GW8VPG/P will be on the Blorenge, South Wales, IO81LS, on Sunday from about 11.00am onwards. I will have 71 & 146.5MHz, talkback 144.750MHz horizontal & Zello. If anyone is operating 5.6GHz, would they please let me know because I have a new receiver that I would like to try out. I will take 5.6GHz only if someone lets me know before.
73 Shaun G8VPG.
Post by g8gtz » Fri Oct 19, 2018 6:18 pm
Just to confirm I will be at Walbury tomorrow at 2pm just to work G4FRE on 71MHz unless anyone requests a sched.
I will also be there on Sunday with 71 and 146MHz plus 24 and 76GHz.
Talkback via 144.750 / mobile / Zello
Post by M0DTS » Fri Oct 19, 2018 7:55 pm
I've now changed plans, will be out portable Sunday instead.
G7JTT
Post by G7JTT » Fri Oct 19, 2018 8:19 pm
Will be out Sunday only at Win Green with 4m Rx and 2m Tx/Rx talk back 2m or phone on 07762112271
John G7JTT
g0uhy
Post by g0uhy » Fri Oct 19, 2018 9:07 pm
I hope to be on from home IO80EK98 at various times over the weekend. If I can find my patch leads and finish the 71MHz PA I should be on 146.5MHz and 71MHz Tx and Rx.
I will be monitoring 144.750MHz and the WhatsApp group. I am also available on 07802 200920 if all else fails.
Malcolm G0UHY
Post by g0mjw » Sat Oct 20, 2018 8:29 am
I will listen for both of you - 2m and 4m. It's too far for 24GHz unless line of sight.
g4bvk
Post by g4bvk » Sat Oct 20, 2018 1:57 pm
Hi John,
John G7JTT
Hi John,
Just to say Win Green is no good for 71 MHz RX as there’s a beacon on 4m only 13 km away.
Ken G4BVK
G8JAN
Post by G8JAN » Sat Oct 20, 2018 5:27 pm
Rob off topic-------if all else fails take some 5 ghz gear with you it's pretty much an ATV desert in west Norfolkshire and I'd love a picture from anybody :cry: :cry: :cry:
Pete
G8JAN (I'm beginning to wonder why?)
1
G4FRE
Post by G4FRE » Sat Oct 20, 2018 6:07 pm
71MHz received over the 135km IO91GI to IO82LB path. Lot of signal in hand
Antenna 5 ele at 15'. Modified G4DDK Anglian transverter into Minituner at 437MHz.
G4FRE/p
G7JTT
Post by G7JTT » Sun Oct 21, 2018 7:27 am
Hi John,
John G7JTT
Hi John,
Ken G4BVK
With that in mind a change of plan I'll go to lane end, which is east of Winchester. Hope to be on site by 10am.
John G7JTT
