May 5th and 6th Activity weekend
g8vpg
Re: May 5th and 6th Activity weekend
Post by g8vpg » Fri May 04, 2018 9:18 am
I can now confirm that I will be going to the Blorenge on Sunday, with 146.5 & 5665MHz ATV. Steve, are you only on Dunstable Downs for the morning and if so, what time will you leave?
73 Shaun.
Post by g0mjw » Fri May 04, 2018 2:40 pm
g8gtz wrote:
Fri May 04, 2018 8:41 am
Currently thinking to go to the Ridgeway above Didcot on Sunday and hopefully work G8VPG, M0SKM and G0MJW.
Probably take 146, 3.4GHz (NB contest), 5665 and maybe 24Ghz.
If you bring 24GHz we will have an opportunity to more than double our previous best DX, possibly even into the double digits - assuming I park a little further away. Wonder if it will work from my Garden? It isn't quite line of sight so a little more of a challenge. Anyone else on 24GHz?
Nobody for 4m?
G8JAN
Post by G8JAN » Fri May 04, 2018 7:33 pm
I may be around saturday afternoon for just a looksee on 24cms and 2.4ghz from my home QTH Unfortunately I won't have talkback but I can record any signals seen if it helps! Sunday is out as it's the North Camp rally probably one of the best in the east midland!
FOA Noel Pete Njj and myself intend to join your group on Wednesday Pete will give you the details.
M0SKM
Post by M0SKM » Sat May 05, 2018 7:06 am
73 Shaun.
Shaun I will have to pack up by about 13:30.
I also have a problem with the Portsdown on 2m which I will try to sort today. 5665MHz is fine.
Steve
G8JAN
Post by G8JAN » Sat May 05, 2018 7:33 am
Can anyone tell me what frequencies you all intend to use today on 24 cms and 2.4 Ghz is anyone operating analogue?
I don't hold out much hope but I'm putting up a small panel antenna for 5.665 Ghz RX. It will be pointing towards GB3PV from my QTH at Downham Market. I don't expect it to be clear of surrounding objects but if anyone is running megawatts there is a very slight chance I may see something. :D
My other antennas are on the mast and fully rotatable. I'll report on here details of any pics received.
Post by g8gtz » Sat May 05, 2018 7:47 am
Hi Peter
Most people use 1255 or 1248 on 23cms - there's no real activity on 13cms although the Luton repeater GB3TZ is on 2326 I think.
Hopefully you'll see something - there's seems to be a bit of activity restarting in the Cambridge area and G4BAO (Waterbeach) was showing off his 5665MHz kit at Martlesham Round Table.
Look forward to seeing you on Wednesday.
Post by g8gtz » Sat May 05, 2018 7:50 am
My plan is Ridgeway - not sure if I can get out in the morning yet but if not will appear at around 1pm.
Will have 146, 5665 and 24GHz.
Shaun - we should make it on 146 but 5665 look tougher.
Mike - is there no /p site a bit further away you can to for a real 24GHz QSO?
Noel G8GTZ
Post by g0mjw » Sat May 05, 2018 8:37 am
Which day?
G8JAN
Post by G8JAN » Sat May 05, 2018 9:08 am
Thanks for the info Noel. Re 5 ghz Pete and I tried out his Sky dish on RX fed with a double Bi quad it worked a treat very sharp! I'm hoping to pick up a dish tomorrow and get something up on the mast. Re Wednesday I'll bring my small dish for RX which sits on the car roof. Hope we have a good take off!
Pete
G8JAN
g7vnpkevin
Post by g7vnpkevin » Sat May 05, 2018 11:12 am
Hi All
I am set up here 23cms tv beaming north from Littleditton Loc JO02FE LIVE FEED ANY ONE A ROUNDS TO DAY
Call Here is G7VNP NAME KEVIN
