Waveshare LCD (A) V3 issue
ZL3TCM
Re: Waveshare LCD (A) V3 issue
Post by ZL3TCM » Tue May 16, 2017 4:25 am
when I was playing around with my display at one stage I managed to get the pins mounted one pin along ( out of sequence) , anyhow reinstalled the LCD module and it went fine but it had stuffed the touch feature. Since bought another module and all good. Sounds like if yours was working but not now then it never will, it is stuffed.
Rob ZL3TCM
Post by g0mjw » Tue May 16, 2017 6:42 am
Mine doesn't work reliably either - they seem to be of variable quality. If I ever get the time I will try to redesign the interface to use buttons. Meanwhile I have ordered a replacement to see if that's any better.
G4HTZ
Post by G4HTZ » Tue May 16, 2017 6:52 am
ZL3TCM wrote:when I was playing around with my display at one stage I managed to get the pins mounted one pin along ( out of sequence) , anyhow reinstalled the LCD module and it went fine but it had stuffed the touch feature. Since bought another module and all good. Sounds like if yours was working but n ot not then it never will, it is stuffed.
Rob ZL3TCM
I have actually done as you described....must get new glasses :D
Good job they aren't too hard on the pocket .
Will get another one
Cheers
Steve
Steve G3GHZ
Canewdon Essex JO01IO
5665 ATV FM
G4HTZ
Post by G4HTZ » Fri May 19, 2017 4:17 pm
Rob ZL3TCM
Cheers
Steve
New screen arrived today ...plugged it in still won't respond to key presses ???.....programme changes appear on the screen ok but that's it
Any clues , suggestions anyone ....
Steve G3GHZ
5665 ATV FM
Post by g0mjw » Fri May 19, 2017 6:43 pm
Sounds like my problem. Have you tried it with the disk it came with - I am wondering if there is a sensitivity issue?
G4HTZ
Post by G4HTZ » Fri May 19, 2017 8:26 pm
g0mjw wrote:Sounds like my problem. Have you tried it with the disk it came with - I am wondering if there is a sensitivity issue?
Haven't tried the disc ....strange the old one was working then stopped ....new one today doesn't respond to touch at all ...but displays any changes via putty
Steve G3GHZ
5665 ATV FM
Post by G8GKQ » Sat May 20, 2017 10:13 am
Steve, Mike
Please could you copy and paste a sample of the Putty response to touch commands here. I can then compare with a working screen and see if there are any changes that I can make to the code to improve things.
Please use a poking stick for the test, not your fingers.
Post by g0mjw » Sat May 20, 2017 10:41 am
Sorry, mine is in bits at the moment. I am starting to finally put it all together in a box.
G4HTZ
Post by G4HTZ » Sun May 21, 2017 1:36 pm
not sure if this is what you needed Dave
/home/pi/rpidatv/scripts/menu.sh: line 1476: 2347 Terminated fbcp
Input device name: "ADS7846 Touchscreen"
Supported events:
Event type 0 (Sync)
Event type 1 (Key)
Event code 330 (Touch)
Event type 3 (Absolute)
Event code 0 (X)
Value 1944
Min 0
Max 4095
Event code 1 (Y)
Value 91
Min 0
Max 4095
Event code 24 (Pressure)
Value 0
Min 0
Max 255
Read Presets
Steve G3GHZ
5665 ATV FM
Post by G8GKQ » Sun May 21, 2017 7:19 pm
Hi Steve
That looks OK for the start-up message, but do you get any additional text when you try to make selections on the screen?
It's the failed selection text that I need.
