Raspberry Pi, DigiThin and Si570 Configuration Procedure
G0NMY
Re: Raspberry Pi, DigiThin and Si570 Configuration Procedure
Post by G0NMY » Sun Nov 06, 2016 10:23 pm
- Modify some config files as superuser using the nano text editor:
"sudo nano /etc/modules"
Use the arrow keys to go down and add the lines:
i2c-bcm2708
12c-dev
Save and Exit by pressing Ctrl-X, Y, Enter
should the above be i2c-dev
I know this is an old post but maybe why the oscillator script errors out ?? :)
Post by G8GKQ » Wed Nov 30, 2016 10:03 pm
Mark
You are correct. I have corrected my original post. Thanks
Post by g0mjw » Wed Aug 28, 2019 4:07 pm
I am trying to get my old PI2 and digithin working but when I select it from the menu it says it is not supported. The old instructions are out of date and links no longer work. I think there is little needs to be done apart from setting the si570 and IQ outputs. It would be good to be able to use it again.
Return to “DigiThin”
