need help whit digilite 5.9
Re: need help whit digilite 5.9
Post by G4EWJ » Fri Dec 20, 2013 11:08 pm
i have observed in the osciloscope that i have digital output signal pins 18 and 22 for "Q" and also on pins 21 and 23 for "I" when I have not connected the USB and SD card, it is correct?
Also when i have not connected the USB ans SD card, I have a digital modulation in the spectrum analyser. it is correct?
and, other question that i have, when i begin to send packet PC to PCB, i don't see output packet in the PC screen. it is correct?
There is always changing data on I and Q, except in TEST MODE = NO MOD, even when the USB and SD card are not connected.
For other test modes, there are single lines on the analyser and not normal modulation.
Does DigiLite transmit say "Looking for recording". If it does, then WinTv is not recording. Can you show a picture here of your DigiLite Transmit screen.
Did you receive my email.
EA7-eol
Post by EA7-eol » Tue Dec 24, 2013 12:34 pm
I sent you a picture of the screen digilite transmission. I sent it to the email, I have trouble uploading to forum
Thank you very much and Merry Christmas
Post by G4EWJ » Thu Dec 26, 2013 11:17 am
I did not receive your email. Can you send it again please.
EA7-eol
Post by EA7-eol » Sun Jan 19, 2014 8:18 am
hello BRIAN
my digilite transmitted.
the problem was in the VCO, proximity was blocking the transmission of digilite even shielded, the VCO
solution
VCO remove or replace the VCO.
Thanks for your help
Post by G4EWJ » Sun Jan 19, 2014 5:20 pm
Very good. :D
Return to “DigiLite”
