I currently DO NOT HAVE the following two types of units that 'must' go to give me some work space in the garage,
hence, free gratis!
UNITS STILL AVAILABLE 12.03.08
1. 4 off NTL MPEG2 Compression Encoder 19"(10U)
2. 1 off NTL MPEG2 System Multiplexer 19"(4/5U)
with the addition of for example a System 3000 DVB Digital Modulator and some sort of RF up convertor (simple homebrew see CQTV221), you have a digital transmission system.
These units are 'first generation' (should all be working) but may be a bit big for 'cupboard' size shacks.
'Take one or take all'. Can probably find a handbook or two, first come first served.
BONUS:
Appart from costs nothing, there are also available a couple of boxes of spare 'PCB's' and possibly some cables.
And, if you scrap any of the units - the switched mode PSU from 2 Multiplexers readily provide a 12/13V typically 50A power supply with other 12,15 & 28V supplies plus 3 x 9cm dia. fans from each unit to cool the PSU at max current and the PA's you might use the power supply for.
And, the switched mode PSU from 2 Encoders readily provide a 12/13V typically 100A power supply with 3 x 12cm dia. fans from each unit to cool the PSU at max current and the your PA's etc.
I have seen similar PSU arrangements on e-bay going for around £100. Why don't I do the same? can't spend the time and effort at the moment.
ROY G8CKN
Location Hampshire.
