BPF 2m
M0NDE
BPF 2m
Post by M0NDE » Thu Jan 08, 2026 6:04 pm
Is the QRP Labs 2m filter a good choice to put between the Portsdown Pluto and a suitable amplifier for 2m experimentation?
Nigel M0NDE
G7JTT
Re: BPF 2m
Post by G7JTT » Thu Jan 08, 2026 8:50 pm
M0NDE
Re: BPF 2m
Post by M0NDE » Sat Jan 10, 2026 8:55 am
Thanks John
I met the "Vic" in the bar at GQRP Convention.
I had also seen these videos prior to my question.
I guess I will have to order one and give it a go.
73 Nigel M0NDE
Re: BPF 2m
Post by radiogareth » Sat Jan 10, 2026 5:11 pm
I'd just include one after the PA, there are some nice cheap amps that re-use MRF186 ('Linear PA' on Ali Express) devices and the PCB includes a filter and VSWR sensing, they go very well on 2m. There area also 70cms versions too and other amps that use a small brick PA and predriver that do 5W DATV on 70. Perfect for local use.
If you fancy a DIY then W6PQL has excellent filter designs for QRO on his website. https://www.w6pql.com/filter_+_coupler_+_detectors.htm
If you used 500V silver Mica caps (or better ATC ones) you would be fine on 2m power levels.
Re: BPF 2m
Post by radiogareth » Sat Jan 10, 2026 5:59 pm
M0NDE
Re: BPF 2m
Post by M0NDE » Sun Jan 11, 2026 12:07 pm
Thank you Gareth for the link. On my next pension day I will order one of these kits for 2m.
73 Nigel M0NDE
G7JTT
Re: BPF 2m
Post by G7JTT » Thu Jan 15, 2026 7:58 am
Just found this on the BATC Wiki
https://wiki.batc.org.uk/images/b/be/2m ... -YU1LM.pdf
John
Return to “Getting Started?”
