Filter hacking for 2395 ISS TV
g4eml
Re: Filter hacking for 2395 ISS TV
Post by g4eml » Wed Nov 05, 2025 8:10 pm
I have just finished building the 20MHz bandwidth S53MV design that uses 40 x 40 x 2 tube and is 280mm long.
After a quick tune on 2395 MHz the results look as expected. A nice shape and a -3dB bandwidth of about 17MHz. Insertion loss about 0.3dB. The -30dB bandwidth is about 57MHz.
I used Gareth's idea of 3D printed end plugs with copper tape on the inside faces and these seem to work fine and look good.
I will try to take some plots and pictures tomorrow.
G4IUG
Post by G4IUG » Fri Nov 07, 2025 8:58 am
Yes please
Thanks Dave G4IUG
Ex G6ANG/T and G8EAO
Post by g0mjw » Fri Nov 07, 2025 9:13 am
They were in Colin's earlier post Dave. Here is the link again http://s53mv.s5tech.net/cavity/cavity.html
g4eml
Post by g4eml » Fri Nov 07, 2025 11:37 am
Sorry I got distracted by other things yesterday. Here is is a picture of the NanoVNA screen. (I can't work out how to do a screen capture!)
And here is a picture of the completed filter.
Post by radiogareth » Fri Nov 07, 2025 12:08 pm
Nice job Colin :-)
Right, back from a brief holiday in Belfast (excellent BTW) and have ordered some 40x40x2 tubing. Cant find any 40x30x2 but as Mike suggested, 'other sizes may work'. Already got 6.5,8 and 9.5 alloy bar and SMA's so i can progress the build.
Based on earlier comments about filters in series and unexpected results, it might be better to build a 10MHz wide filter rather than a pair of staggered 20MHz wide, one tuned high, one tuned low to get the reduced bandwidth of interest. "Similar loss" either way in an ideal world????
Next question...where best to place a preamp? Given the size of the 5g signal, it would seem wise to put any gain after the 5g and wifi has been curtailed a bit, but will the insertion loss be a deal-breaker? At around 0.4dB I'd guess not, but happy to be told otherwise.
g4hiz
Post by g4hiz » Fri Nov 07, 2025 12:57 pm
Yes, Colin's filter looks very nice!
Regarding where to put the filter. What is the impedance of your feed and the input of the LNA across the frequency band of interest, and that means not only the passband but the rejection bands also? If there is a good match, you may be lucky and retain something that looks like the VNA sweep. Otherwise, the filter shape can change somewhat. The coax connections between the feed and filter input and filter output to LNA input will also add to the mix in terms of the impedance transformations potential created by them. In the worst case, the LNA may oscillate at some strange frequency due to the impedance appearing at its input.
It also depends on what LNA you intend using. The VLNA as designed by G4DDK was from my recollection, intended for contest scenarios, meaning potentially high local signals. From the experience of using one in my own system, I have not had any issue putting it in front of the filter.
In my system, the VLNA connects to the POTY feed using an SMA barrel. I have used attenuators at the input and output of the filter to improve match and stability, especially with the following amp in mind. The LNA gain should compensate for these.
So I'd put the LNA in front of the filter.
Jen
Post by g0mjw » Fri Nov 07, 2025 1:16 pm
Nice job Colin :-)
I would use a different design with more poles. Look here https://www.w1ghz.org/QEX/Waveguide_Int ... ilters.pdf and at the calculator program linked here https://www.w1ghz.org/10g/Filter_articles.htm but it requires old windows. I think you could simply get away with a 5 or 6 pole based on the 3 pole with 2 or 3 elements added of the same design. Don't try to cascade two, it won't work.
Return to “ARISS HamTV”
