Portsdown 4 enclosure options?
G4GHD
Post by G4GHD » Mon Oct 20, 2025 10:50 am
I've recently built a Portsdown 4 and am using the 7" screen as mentioned by Gareth G4XAT on page 24 of CQ-TV 289.
Unfortunately this screen has different mounting point spacings from the official Pi 7" touchscreen, which would appear to rule out the SmartiPi Touch 2 Case, which has been mentioned on the forum previously. Any other suggestions? FWIW, the screen's horizontal mounting holes are spaced approx. 155mm apart, while the vertical spacing is about 93mm.
Re: Portsdown 4 enclosure options?
Post by g0mjw » Mon Oct 20, 2025 11:49 am
I would suggest a 3D printed case. I have been working on a design with Colin, G4KLB. We can send you the STL files.
Screenshot 2025-10-20 125511.png (23.21 KiB) Viewed 1610 times
Mounting the screen is easy, it just requires two brackets making, one for either side to fit to the case. You can either 3D print something or just bend a sheet of aluminium.
Screenshot 2025-10-20 125256.png (63.62 KiB) Viewed 1610 times
G4GHD
Post by G4GHD » Mon Oct 20, 2025 3:39 pm
Thanks Mike, looks good, but regrettably I don't have a 3D printer myself.
Post by radiogareth » Mon Oct 20, 2025 5:07 pm
How about one of these, but mounted on its back, ie standing upright and 'looking up at you'?
https://www.ebay.co.uk/itm/406288742719
or something like this?
https://www.tme.eu/gb/details/g1507/des ... es/gainta/
I googled "console instrument case" which throws up several options.
G4GHD
Post by G4GHD » Tue Oct 21, 2025 1:55 pm
Thanks Gareth,
that first one looks like a contender, but I'm not sure if heat and ventilation will be a problem in that orientation.
Post by radiogareth » Tue Oct 21, 2025 5:17 pm
I've used a small fan and in/out vents on my first one, nothing on the second but used a clamshell wraparound passive heatsink and sprayed the box inside with nickel spray to keep the RFI in. Very little temp difference reported between them. Use decent stick-on heatsinks and it will be fine. If it overheats the height would give good convection with a few well placed holes.
G4GHD
Post by G4GHD » Tue Oct 21, 2025 6:08 pm
Thanks again Gareth, that's good to hear.
G4GHD
Post by G4GHD » Sun Nov 16, 2025 2:27 pm
As an update, I opted for the case that Gareth suggested. My chassis-bashing skills are poor at the best of times, I managed to cut out the hole for the touchscreen, but, even after filing, it's still a bit rough.
As for the case itself, it's a good size, with ample room should you wish to add Langstone functionality and a speaker on the top panel too.
