Apologies if there is a better area of the forum to post this in.
Building a Portsdown4 was going ok until...
Newly purchased Pluto rev C. I thought I had bricked it but I've now got the F5OEO firmware installed and plugged into a USB3 port I can see the drive (E:) from my PC and can bring up the info page with http://192.168.2.1/
Connected to my PC via USB the ready LED is on continuously but LED1 repeatedly blinks twice (like .. .. .. .. ..)
Plugging into the Pi in my Portsdown4 it doesn't find Pluto.
I've spent a lot of time searching but been unable to find a solution.
Barry G4IAT
Pluto problems - blinking LED1
Re: Pluto problems - blinking LED1
What firmware did you install and what patches?
As supplied Pluto firmware was v0.32. I then installed v0.39, then F5OEO v0.31-4-g9ceb-dirty
I'm only planning to use it locally on 23cm so have not extended the frequency range or enabled the 2nd processor.
I wasn't aware of any "patches" being needed.
I suspect that might be the problem then. Enable the second CPU. It is working with the PC I assume? The correct info page, not the original AD one.
The guidance is in the Wiki, https://wiki.batc.org.uk/Portsdown_4_Pl ... o_Firmware - do not deviate from the path.
It goes without saying, make sure you are using the latest Portsdown 4 version, fully updated and that you have a functioning USB cable, that you have a decent PI4 power supply etc. Do not apply more than 5v - see the wiki.
I am using later firmware, version 0303 and with a REV-C, that needs a patch. I don't use that with the PD4 The older version you installed should work without one, according to reports, but I don't have practical experience as I do not have a rev c.
