HamTV Reception Reports
Please provide reception reports by posting to this topic. It would be good if you could include details of Dish size, receiver, decoding software, reception time, reception duration, peak MER and picture content.
(as an example: 80 cm dish, G4DDK preamp, Calafornia Amplifier downconverter, PicoTuner and Ryde, start 1505 UTC, end 1508 UTC, peak MER 8 dB, blank raster)
Re: HamTV Reception Reports
Pleased to say that I received HamTV on the first pass after switch-on:
G8GKQ IO91CC Salisbury, Southern England.
90 cm dish, G4DDK preamp, California Amplifier downconverter, PicoTuner and Ryde, start 1505 UTC, end 1508 UTC, peak MER 15 dB, blank raster (352x480 no blue line)
- IMG_6137.jpg (111.81 KiB) Viewed 9697 times
Well done Dave.
Now for the rest of us to follow......
I've just seen it on a second pass (1642 to 1645 UTC) as well. It's a strong signal - here is the spectrum on BandViewer (note that my IF is 731 MHz)
Dave G8GKQ
Dave G8GKQ
- ISS Bandviewer.jpg (74.07 KiB) Viewed 9662 times
Congratulations Dave. You were getting better results than me I could only manage MER 8.9 on the second pass. The first pass was a failure so nothing to report.
Dish - 1m Prime Focus Mesh, LNA TQP3M9073 Ali Exp, Minitiouner for receive. Only 2 mins receive 16:43 to 16:45, MER 8.9, C/S HAMTV, Black Screen.
Photo won't upload as file too big so I will put it on my Bluesky page.
Nick
G4IMO
Nick
G4IMO
vu2jek_nitin
Glad to join this forum. I am working to have the setup for ISS HAM TV RX. I will be watching the ARISS Live stream at 12:40 ,14:15,15:50, and 17:28 UTC when the ISS has the foot print over UK.
73, Nitin VU2JEK
73, Nitin VU2JEK
First reasonable report from me...
150 cm dish, POTY feed, G4DDK preamp, 'pipe cap' filter, Kuhne Downconverter, Portsdown Rx, start 1417 UTC, end 1422 UTC, peak MER 17.
Portsdown shows a squashed image (vertically) and squashed overlay text, anyone else get that?
Pass was up to ~40deg elevation, signal has lots of fading until it gets past south heading east, then it's much stronger.
Sun vs cold sky noise is ~8dB today.
IO94IL
54.5N
The next pass recording:
https://www.youtube.com/watch?v=EVWw4VxaKvA
IO94IL
54.5N
Hi Rob
Yes - I had similar results with the Portsdown. I think that it is because the transmitted (blank) raster is 352x480, so much smaller than the touchscreen. Hopefully it will at least grow to 720x480 (which it was when we last saw a picture) when a camera is connected.
8 dB of sun noise is impressive. I only achieve about 1.8 dB. My MER on the 1420 UTC pass reached 15 dB though, but it was higher elevation at 73 degrees for me.
Some of the fading could be due to blockage by the structure of the ISS. I recall this was an issue the last time it was active.
I received something from last pass over Dublin.
First attempt. Dish 1m mesh, kuhne super low noise down converter with local oscillator of 916.5MHz, RF hamdesign circular feed from Netherlands, Minitouner Pro v1.1.
Dish was handheld, but it locked a good bit. Pass prediction was max 51 degrees pass. I have az & el rotator but was not used.
Dan EI9FHB in Dublin
