Portsdown stream receiver input
KA5BBC
Post by KA5BBC » Sun Jul 06, 2025 7:07 pm
How does one build, configure, and implement the Portsdown stream receiver input for the repeater controller?
I'm assuming that I would need to build a Portsdown for each stream input (hopefully headless rather than needing more screens etc.) but where do I go from there?
Andy, KA4BBC/MM0BQV
Re: Portsdown stream receiver input
Post by G8GKQ » Sun Jul 06, 2025 7:51 pm
Andy
The recommended solution is not to use a Portsdown, but to use a Ryde for the stream input. This is of course headless and does not need an IR remote control. It is all configured in the config.yaml file.
KA5BBC
Post by KA5BBC » Sun Jul 06, 2025 8:03 pm
Thank you again Dave..
There is a bit of a learning curve but I will get there.
I have no doubt that there will be many many more questions before I am done
Andy, KA4BBC/MM0BQV
KA5BBC
Post by KA5BBC » Mon Jul 07, 2025 8:29 pm
OK.. Ryde is built enough to operate a stream receiver.
(I am waiting for components to populate the GPIO breakout and control boards I have)
How do I configure it so that those given a suitable IP and log in can access the repeater?
Andy, KA4BBC/MM0BQV
