4 or 6 port coax relay / switch
If you are looking for something, ask here
gu6efb
Post by gu6efb » Sun Jan 26, 2025 9:26 pm
Hello
I am looking for a 4 or 6 port coax relay / switch.
Would anyone have a surplus unit sitting on a shelf that there are willing to sell?
I have looked e-bay but don’t want to be paying £250 up for a second hand unit.
Happy to pay a fair price, or does anyone know of a reliable source of these type of units?
73 Keith GU6EFB
VK5BI
Re: 4 or 6 port coax relay / switch
Post by VK5BI » Sun Jan 26, 2025 10:08 pm
Keith,
Contact Jac ,pa3dzl@icloud.com and ask him to email you his current list of products for sale.
He provides excellent service.
Regards
Wayne
gu6efb
Post by gu6efb » Mon Jan 27, 2025 10:19 pm
Many thanks Wayne for the info.
Email sent and awaiting response
Many thanks for the help.
73 Keith GU6EFB
Post by g0mjw » Tue Jan 28, 2025 8:47 am
Hi Keith,
You didn't give the specification. Is this for HF, VHF, UHF, SHF? Power rating? Connectors?
6 port and 4 port SMA relays were often available at rallies very cheap as nobody really wanted them. I remember seeing piles of them at Dayton and Friedrichshafen in the early 2000s. Fewer in the UK, but still plenty. Where have they all gone I wonder? There was a chap selling lots at Newbury 3 years ago, not seen them since.
If it is just for HF and low VHF (up to say 6m) then you really don't need a coaxial relay. There is a chap in Bulgaria selling 6 way switches based on relays. These are also on Aliexpress/Ebay from China https://www.ebay.co.uk/itm/134231762073 - That's what I am using with my IC7300 to select between antennas for HF Dipole/HF vertical/10m/6&4m/4m vertical based on that 8-way antenna switch board I designed that I think you built.
If it is for higher bands, be aware that the ratings of the SMA switches vary. Some are rated at 100W, some more, others much less. That to the extent that this may not be the best way to do it.
You can for example use 3 CX-520s (other coax relays exist) to create a 4-way switch that would handle 300W on 2m and 70cm and 200W on 23cm. They are expensive new but very often found surplus as they were used in old analogue mobile radio base stations. Quite often TNC relays are available because nobody want to use a TNC, despite them being rather good connectors. The Apollo ground station at RAL used many TNC relays, so they can't be that bad. These can be driven with minor changes to the software and are expandable as adding a relay adds a port. Not so good for cumulative losses, but if you can always arrange for the most critical bands to pass through the fewest relays.
gu6efb
Post by gu6efb » Wed Jan 29, 2025 11:16 am
Hi Mike
Many thanks for the info just looking for a unit to fit in my Portsdown build to deal with RX and TX switching.
TX switching is at the drive level so very low power covering HF and above, I have at least started this project with a large housing but will still
properly still run out of space.
Keith
Post by radiogareth » Wed Jan 29, 2025 11:20 am
Can't get much smaller than this.....might suit your needs....
https://vi.aliexpress.com/item/10050059 ... pt=glo2vnm
Ready built too....
DL5BCA
Re: 4 oder 6 Port Coax Relay / Switch
Post by DL5BCA » Fri Feb 14, 2025 8:48 pm
I always have crazy ideas.
Please don't be surprised.
Post by g0mjw » Sat Feb 15, 2025 10:44 am
Hi Mike
Keith
Certainly up to 70cms, as long as you don't want too much isolation, you can use miniature 12V relays. Maybe we should design a PCB for this? Something like :
Screenshot 2025-02-15 104228.png (54.49 KiB) Viewed 7423 times
Maybe?
Post by g0mjw » Sat Feb 15, 2025 3:18 pm
Or maybe
Screenshot 2025-02-15 145710.png (36.38 KiB) Viewed 7321 times
Though the board would need to be on 0.8mm PCB to make the 50 ohm tracks thinner. The idea being that the higher bands have the easiest path and other bands, where it doesn't matter so much make do with a bit worse.
Put it in a Hammond diecast box
Screenshot 2025-02-15 151737.png (319.17 KiB) Viewed 7321 times
and a 4 port version as who needs 6.
Screenshot 2025-02-15 162519.png (37.38 KiB) Viewed 7294 times
Return to “Wanted”
