Open Tuner 0.B
Jabier
Open Tuner 0.B
Post by Jabier » Tue Jul 02, 2024 5:18 am
See down
Jabier
Re: Open Tuner 0.B
Post by Jabier » Wed Jul 03, 2024 4:17 am
Good morning:
The adress is:
https://github.com/SV8ARJ/open_tuner/releases
73,s de Jabi, ea2aru.
g6hfs
Re: Open Tuner 0.B
Post by g6hfs » Wed Jul 03, 2024 12:23 pm
Nice idea, but I only use ethernet option as usb flakey and crashes.
DJ7TH
Re: Open Tuner 0.B
Post by DJ7TH » Thu Jul 04, 2024 9:51 am
Various tests with my homemade PicoTuner V2 with USB and Ethernet connections have shown that you can start the version by Tom ZR6TG multiple times and thus create 2 windows each time by copying the complete software into several folders and starting the respective opentuner.exe there.
The current version 3 by George SV8ARJ does not allow this and can only be started once.
However, Tom's version can only be started once in Ethernet mode, even though I had assigned various IP addresses to the Ethernet ports.
I discovered another problem with both versions when using the ffmpeg player in both windows.
Sometimes the player works without any problems, sometimes just an empty window opens.
Only when I use the mpv player in one window, does the ffmpeg player also work in the other window.
It would be interesting to know if this only happens to me.
vy 73 de Rolf -DJ7TH-
www.qrz.com/db/dj7th
73 de Rolf -DJ7TH-
