DVB-T SDR Question with Pluto
G1BVI
Post by G1BVI » Fri Dec 15, 2023 3:26 pm
I tested my Knuckler/Ryde with my PD4/LimeUSB transmitting DVB-T without issue.
I tested the Knuckler/Ryde with an off the shelf Pluto transmitting DVNB-T without issue.
This combination also works as an FM/J3E TX/RX .
However When using a Pluto flashed with the F5OEO and patch as per ZR6TG's web site it will not transmit DVB-T that I can resolve nor does FM /SSB work properly.
Am I right in assuming that the F5OEO firmware and patch is only designed to work on DVB-S
If I downgrade the Pluto to the reccomended 0.31-4 will it
1 still work as a DVB-T TX
2 Will it work as a DVB-S TX for QO100 operation.
Thanks all
Nick
G1BVI
N6MX
Re: DVB-T SDR Question with Pluto
Post by N6MX » Sat Feb 24, 2024 6:49 pm
I'm also struggling with transmitting DVB-T from a Pluto and being able to decode the signal with a known working HiDes receiver. I'm not sure if my issue is the same as the one mentioned here, but I also have the F5OEO firmware so I'm wondering if I should roll the firmware back and try again.
I'm also wondering if anyone has the answer to G1BVI's questions?
Thanks,
Dylon N6MX
Post by g0mjw » Sun Feb 25, 2024 9:13 am
Thanks,
Dylon N6MX
Is that at 300ks/s or 2ms/s?
Make sure you have read the threads on powering the Pluto as it seems more critical with DVB-T. I assume this is with 0303 Firmware?
It has been a long time since we experimented with DVB-T as it was found not to work as well as DVB-S/S2 in most cases and amplifiers tend to produce less power with acceptable quality. I think the last time I used it was for testing the NEC 70cm amplifier pallets we obtained a few years ago.
Post by G8GKQ » Sun Feb 25, 2024 11:34 am
I don't know how many times I need to say this:
THE PORTSDOWN SOFTWARE IS ONLY DESIGNED TO BE USED WITH A PLUTO LOADED WITH v0.31-4-g9ceb-dirty FIRMWARE
Please don't complain if it does not work with any of the many other Pluto firmware versions available. It just winds me up!
Post by g0mjw » Sun Feb 25, 2024 12:28 pm
Sorry Dave,
I forgot to mention that. I hadn't twigged this was with a Portsdown.
SkyVision
Post by SkyVision » Mon Feb 26, 2024 11:27 am
Have any more of those excelent 70cm pallets ever come to light
Is there a particular DVB-T txer I should be looking out for?
Cheers Roger
G4HTZ
Post by G4HTZ » Sat Mar 02, 2024 2:44 pm
Cheers Roger
Hi roger
I have one of the complete units containing is 10 or 12 boards …whatever it is …was going to used for a project but since moving house 18 months ago its still in the house moving box …so i will probably sell it at some point
Regards
Steve G4HTZ
Steve G4HTZ
PORTSDOWN and a RYDE …
G4HTZ
Post by G4HTZ » Sat Mar 02, 2024 2:51 pm
Cheers Roger
Hi roger
Regards
Steve G4HTZ
Actually there’s still complete 2 units on eBay for £400 each
Steve G4HTZ
