Open Tuner 0.7 - Dual Tuner/FFMPEG, etc
g6hfs
Re: Open Tuner 0.7 - Dual Tuner/FFMPEG, etc
Post by g6hfs » Thu May 11, 2023 5:45 pm
Hi all,
Found the problem a duff 74HC10, glad I put an i.c socket on the pcb, all working so thanks all and Tom ZR6TG.
Basil
Post by Basil » Thu May 11, 2023 7:14 pm
Ebay? My patience quotient just rose... :) Will have things socketed... Thanks for letting us know the cause Brian.
Best regards,
G8KOE
Post by G8KOE » Wed May 31, 2023 11:04 am
Hi Tom,
I have been using OT 0.7f Dual mode with Media Player 1 set to FFMPEG and Media Player 2 set to VLC.
Some days it locks up I have to restart OT or it disappears and have to relaunch OT.
I changed to Media Player 1 & 2 set to FFMPEG seems to run faultless.
Next I set Media Player 1 & 2 to VLC after a time lost control of Tuner 2 and had to restart OT.
My PC runs Windows 11 with all its updates.
That's my findings so far.
Hope the information may help.
73's
Martin
G8KOE
Pa3fbx
Post by Pa3fbx » Thu Jun 01, 2023 2:45 pm
The dual TS will also work on the minitiouner S- but the Hugh expensive ftd mini module will never fit into the original box.
This made me look for a different solution.
I draw kicad the schematics and an pcb witch fits with only the needed 14 output wires.
I made a 10 piece shipping from china and it seems to be under 15 euro.
So i might have an solution for those who cannot use the batc minitiouner version 2 solution.
Benno
G7VVF
Post by G7VVF » Tue Jun 06, 2023 1:07 pm
I have a question about this.
Could you make a dual Ryde system using one minituner with an extra usb interface connected to 2 x Rpi4s
If so, this could be used as a dual band repeater RX, with a cost saving and more importantly a Serit tuner saving!
Duncan
G7VVF
Post by G8GKQ » Tue Jun 06, 2023 1:18 pm
Hi Duncan
This would be difficult to implement as all the control for the tuning of the second receiver channel is implemented on the primary USB interface. The status (tuning and SR) of the second receiver channel cannot be controlled through the second USB interface.
This is the way that the Serit Tuner is designed and not something that we can change.
Great idea, but...!
Pa3fbx
Post by Pa3fbx » Mon Jun 12, 2023 1:40 pm
Still, if the control is made trough the first ryde system and the second ryde is only the second transport stream viewer it would be possible..
Decoding 2 H265 Transport streams on 1 raspberry is a not possible due to the cpu limits.
But if you think about the portsdown steaming options this would be an other story.
1 control portsdown and 2 output streams... But the controlling of 2 separate RX channels would be something difficult to GUI...
But than again i know Dave is much to occupied, to accept more portsdown work. and most of us already have multiple receivers installed so what's the need.
Benno
