LOST OpenTuner Display
G8KOE
Post by G8KOE » Mon Jun 05, 2023 5:10 pm
My PC has three screens connected and running Windows 11.
I have lost OpenTuner display.
I get the same results on my BATC MiniTioune and my Pro V2.
This is all I get when try to run the program.
Need Help
Martin
G8KOE
G8KOE
Re: LOST OpenTuner Display
Post by G8KOE » Tue Jun 06, 2023 6:05 am
With a suggestion from TECH MINDS Matt downloaded and reinstalled OpenTuner.
Run from my download directory all worked OK.
Removed the original OT program and replaced with newly downloaded program.
I was then back to original fault.
Providing I put OT anywhere else on my computer all works OK.
Windows must but be associating the corrupted parameters.
Thank again to Matt for his help.
73's
Martin
G8KOE
G7JTT
Post by G7JTT » Tue Jun 06, 2023 8:47 am
Just a thought Martin, your not running OT in a protective directory? I've had several problems with this and I just created a directory called radio in the root of the C drive and install everything there.
73 John
M0SKM
Post by M0SKM » Tue Jun 06, 2023 8:54 am
John,
Yes I had a similar issue some years ago I done the same as you, minitioune goes in there too. Just create links to the desktop.
Steve
on6py-Rudy
Post by on6py-Rudy » Wed Jun 28, 2023 7:54 pm
Ohannes ZS1SCI sugested this simple solution on WhatsApp:
- Right click the taskbar icon
- When open and click maximize
Tnx Ohannes!
Afbeelding van WhatsApp op 2023-06-27 om 18.27.28.jpg (13.96 KiB) Viewed 18740 times
G8KOE
Post by G8KOE » Wed Jun 28, 2023 8:46 pm
The configuration file is stored under %userprofile%\appdata\local\Amateur_Radio_-_ZR6TG
So your should be able to enter %userprofile%\appdata\local\Amateur_Radio_-_ZR6TG into a run dialog and get the folder
for example:
To open run dialog:
Windows Key + R
Press enter and you should get something along these lines:
Go into that folder and there will be a user.config file you can edit to restore those settings
This information was from Tom when I has the problem.
I deleated the configs and started again.
Hope this helps.
73's
Martin
G8KOE
