Second usb port pcb
g6hfs
Second usb port pcb
Post by g6hfs » Thu May 11, 2023 2:12 pm
Having issues getting 2nd video on minitiouner v2 with opentuner, the small daughter board calls for a 74HC10 but can only find them with extra part numbers like /n etc, does this matter or has it to be 74HC10 only.
Re: Second usb port pcb
Post by radiogareth » Thu May 11, 2023 3:24 pm
I'm using some NOS I got from Langrex on eBay (cheap enough), they are 1983 date code and also finish with an N. Mine works. Got a vague recollection tis the package type, but not 100% sure.
g6hfs
Post by g6hfs » Thu May 11, 2023 4:20 pm
Gareth,
I must have a problem somewhere else I will have to take another look and see if a connection is missing.
Dud you programme the module with the file on Tom's Web site.
Glad yours works, I take it you used the batc pcb from shop.
g6hfs
Post by g6hfs » Thu May 11, 2023 5:37 pm
Hi all,
Thanks for all the replies, but as I said you may have a duff 74HC10, I did duff final o/p to usb module so use a socket.
So all working after putting a scope on the chip to check signals.
Thanks all and Tom ZR6TG
