Open Tuner 0.7 - Dual Tuner/FFMPEG, etc
g6hfs
Re: Open Tuner 0.7 - Dual Tuner/FFMPEG, etc
Post by g6hfs » Wed May 10, 2023 10:35 am
Ok thanks will look at reprogramming.
g6hfs
Post by g6hfs » Wed May 10, 2023 11:00 am
Have reprogrammed the second usb module, now get dual display but window B has info but no stream, need to find out why now.
zr6tg
Post by zr6tg » Wed May 10, 2023 12:53 pm
Hi Brian,
Thats a good start, I'm going to need the terminal log to see whats going on. Can you start it and share the ftid section (in the beginning when you just connected).
g6hfs
Post by g6hfs » Wed May 10, 2023 1:47 pm
Tom,
Is this what you need
zr6tg
Post by zr6tg » Thu May 11, 2023 10:59 am
Yes, there it shows the problem. The B port for your daughterboard is not enabled as a fifo port. Are you using the template, or did you directly change the USB descriptor strings?
On that screenshot ftdi device 2 and 3 (which is your new module) should show true next to fifo.
Its detecting it properly now, but your module isn't configure 100% yet.
- sorry for slow replies, I'm busy travelling for work.
g6hfs
Post by g6hfs » Thu May 11, 2023 11:15 am
Tom,
Understand, the module was programed wih the file on your site, do you have to change any parameters before applying template and then program.
g6hfs
Post by g6hfs » Thu May 11, 2023 11:39 am
Tom,
Reprogramed usb 2 from file again, now its says fifo true for B again no video so not sure how to proceed, any more info or checks I need to do.
Basil
Post by Basil » Thu May 11, 2023 1:32 pm
If I were to solder the FTDI board direct to the daughter board from the BATC will that mean I cannot then programme or re-programme the FTDI chip? I was considering reducing the number of mechanical connections but if it's then not programmable I have made myself a little paper weight :) Thanks. I also seem to have every 0.1 inch header combination imaginable. Save the ones I need of course...
Best regards,
g6hfs
Post by g6hfs » Thu May 11, 2023 1:59 pm
Hi Basil,
Yes you can still program the chip, but that would make it a problem if you had to replace the the 74HC10 chip on daughter pcb, I used headers and a chip socket, same as the original usb module and chip.
I am still trying to sort mine out as no second ts video, also not sure if it has to be 74HC10 most chips have other part numbers on.
Basil
Post by Basil » Thu May 11, 2023 2:49 pm
Thanks Brian, I guess I'll have to be patient and get some headers in, since my account with RS Components stopped being honoured with free postage I find getting small orders in a timely manner is back to using Ebay, where any old junk is likely to be on sale. Good luck with yours, often the chip numbers are relatively innocuous, stuff like lead free tinning and temperature ranges, original batch quantities, packaging, blah blah.
Best regards,
