Store LNB power and set to one tuner
PE5PVB
Post by PE5PVB » Fri May 05, 2023 7:48 pm
How can I easy set Horizontal as default LNB power and reduce to only one NIM?
Re: Store LNB power and set to one tuner
Post by radiogareth » Sat May 06, 2023 7:11 am
Could you not just rotate the LNB 90 degrees so it needs 12V for the WB?
PE5PVB
Post by PE5PVB » Sat May 06, 2023 11:26 am
Just found the setting for the LNB power. Only question left is to disable the 2nd tuner. In the spectrum view I can only tap on the top range of the screen. How can I enable to use the whole screen to tap on?
zr6tg
Post by zr6tg » Mon May 08, 2023 9:16 am
The next version is a bit smarter and will adjust the spectrum based on the amount of transport streams. If you only have 1 transport active then it will work as the normal spectrum with a single signal for the whole screen. Should be released tonight depending on testing.
T
